    πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Delightfull Clark lamp
    17 Posts 10 Posters 879 Views 10 Watching
    • massimoM Offline
      massimo Moderator
      "Its structure is made in brass, covered by a golden bath just like real trumpets are".
      Love this lamp. πŸ˜„
      SU+Thea.
        jpalm32
        Really cool lamp. Is it an actual product or yours?
        • Rich O BrienR Online
          What's going on in that filament?
          You know why I need to know...
          It's great BTW
          • olisheaO Offline
            olishea
            The master at work.
            Beautiful convincing DOF, the subject lends itself well to the effect.
            πŸ‘
            oli
            • massimoM Offline
              massimo Moderator
              Thanks guys. πŸ˜„
              @John: no it's designed and produced by a Portuguese company;
              @Rich: the filament is a tube with a fluorescent 65W warm Thea's emitter mat applied on it. Rendered with TR2 SS-->high. In the darkroom I've applied at the end a radial glare with weight=1% and radius=2%. The bulb has thickness and is a thin glass. That's all I believe;
              @Oli:
              indeed, almost a natural DOF.
              • cheddaC Offline
                chedda
                Excellent image & modelling.
                Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                • massimoM Offline
                  massimo Moderator
                  Thank you. πŸ˜„
                  • tinanneT Offline
                    tinanne
                    Great job! Love the DOF.
                    Executive Director : American Society of Architectural Illustrators
                    AIP 30 Competition opens soon. ASAI.org
                    Architectural Rendering
                    • massimoM Offline
                      massimo Moderator
                      Thanks Tina. πŸ˜„
                      • tademaT Offline
                        tadema
                        Brilliant πŸ‘ πŸ‘ πŸ‘
                        • HieruH Offline
                          Hieru
                          Can't really add much more. Great choice of subject and perfect materials and lighting.
                          Did you use HDRI for lighting, or did you throw in some emitters?
                          www.davidhier.co.uk
                          • massimoM Offline
                            massimo Moderator
                            Thanks Tadema & David. πŸ˜„
                            David, I've used a HDRI by Debevec called "Ennis Brown" which suits quite well for this kind of subjects/materials. Anyway emitting planes are also very good for this kind of scene since you can have more control. Then I've placed the lamp in the screen you see in the picture below quite near to the wall since I wanted to see some light projected on the wall in the centre of the image.
                            Finally I'm glad you like the mats: the plated brass is made with a stacked brass&gold nk mats using a grey map with stains in weights in order to have a subtle transition between the two metals in some parts.
                            • elmerE Offline
                              elmer
                              Great work....as usual πŸ‘
                              • HieruH Offline
                                Hieru
                                Ah, the ever reliable Ennis scene πŸ˜‰
                                Sounds like a good use of materials.....I just knew you had done something interesting in the mix πŸ‘
                                www.davidhier.co.uk
                                • massimoM Offline
                                  massimo Moderator
                                  Thanks for the kind words Elmer. πŸ˜„
                                  • Bryan KB Offline
                                    Wow!
                                    • massimoM Offline
                                      massimo Moderator
                                      Thank you Bryan. πŸ˜„
