    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 69.0k Views 16 Watching
    • renderizaR Offline
      renderiza
      @smicha said:
      Ctrl function is not working - I installed it twice.
      At the moment it seem that when the GOSU web dialog window is focused it doesn't recognize the keyboard so to fix it follow this steps until I can solve it on code...
      1. click Set::Proxy on dlg window
      2. Use middle button to orbit around so the dlg window is not focused anymore
      3. Hold Ctrl and click component
      4. Let me know if it worked because if not then the problem is not what I have in mind. Also just in case delete web cookies and download again because since I used same name as the one I had uploaded before it might had something to do with that (not sure).
      @smicha said:
      Another improvement would be proxy on a single group, not a component.
      At the moment the Definition Name is being used to set proxy and only components can have them. Not saying it cannot be done with groups but it will take more time to make it work.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        smicha
        Refael,
        Isn't it better to do two separate functions - proxy with boxes and proxy with clines? That could let a user assign different shortcuts to such functions.
        I'll test your plugin tomorrow morning.
          renderiza
          GOSU v1.0.7 Released!
          [highlight=#bfff00:2t64rsa8]1.0.7:: 4/29/2013[/highlight:2t64rsa8]
          • Set:: Proxy(box) - Added this to web dlg
          • Set:: Proxy(cline) - Added this to web dlg
          You can set a keyboard to Set::Proxy(box or cline) and No::Proxy(box or cline)like this
          To set key shortcut to Set::Proxy(box or cline);
          1. Select component
          2. Got to Window menu
          3. Then Preference
            4 On the left side click 'Shortcuts'
          4. On Filter type cline
          5. This should appear...Edit/Item/GOSU/Set::Proxy(Cline)
          6. Add Shorcut
          To set key shortcut to No::Proxy(box or cline);
          1. Select component that is already with Proxy(Cline) Aplied or it will not work
          3. Then Preference
          5. This should appear...Edit/Item/GOSU/No::Proxy(Cline)
          6. Add Shorcut
          By the way ::smicha:: thanks for making suggestions! This will make GOSU better. πŸ‘
          Cheers!
          • Rich O BrienR Online
            Added to store
              renderiza
              @rich o brien said:
              Added to store
              Thank you very much!
              • CadFatherC Offline
                CadFather
                Thanks Rafael, it's a fun plugin!
                would be great if it went stealth - fantastic for jokes - imagine your boss clicks an object during a presentation and the appropriate sound goes off! πŸ˜†
                  renderiza
                  That would be hilarious indeed! πŸ˜† ...Hope no one gets fired. πŸ˜•
                    smicha
                    Here is a problem: I assigned F3 to cline. When I press F3 and select a component nothing happens. When I select a single component and press F3 it works but when I want to remove cline - no way to do it with F3. I also cannot convert all same components to clines with F3.
                    Thanks for your effort Rafael.
                      smicha
                        renderiza
                        The way Set:: Proxy(cline) works at the moment is that it only can handle multiple component objects at the same time if they all are part of the same instant group.
                        Also you can't assign same shortcut key to both Set::Proxy(cline) and No::Proxy(Cline) because they are consider two different actions. This mean you can set one to 'F3' and the other to 'F4' for example.
                        You can't convert all same instances like you did by double clicking using the web dlg with the shortcut key because that is a different action that is only triggered with double clicking. To make that work using a key shortcut I will have to assign a context tool specially for that task, if I do this you can't assign it to same shortcut key as 'F3' or 'F4'. It will have to be 'F5' and if you want to turn them all back 'F6' πŸ˜•.
                        I know this is getting complicated to explain but I hope you got what I was saying. I will try to see if I can make it so that you use one shortcut key but at the moment I don't know how.
                        Cheers! πŸ‘
                          renderiza
                          Ok just solved how you can use same shortcut to toggle Proxy on & off so that you can use F3 for both actions (this was simpler that I thought to solve 😳).
                          To make every instance of that component you selected turn proxy on & off like it did with double click action another key might be needed (F4) but it will be the same key to turn everything on or off so its good.
                          As to work a way to turn all selected components to proxy even though the are not same instance of each other that might be more tricky so it will take longer to figure out...at least for me. πŸ˜„
                          Anyways the new Gosu version bet "Bugs" fixed will be release soon.
                            smicha
                            I'll test it ASAP Rafa and let you know. Thank for such fast correction.
                              renderiza
                              GOSU v1.0.8 Released!
                              [highlight=#bfff00:2kvzuda1]1.0.8:: 4/30/2013[/highlight:2kvzuda1]
                              • Set:: Proxy(instances) - Added this to context menu
                              • Set:: Proxy(box and cline) now use the same action to turn on & off (this is useful to set shortcut key)
                              Edit/Item/GOSU/Set::Proxy(Box) - Uses same action for turning proxy on & off now
                              Edit/Item/GOSU/Set::Proxy(Cline) - Uses same action for turning proxy on & off now
                              Edit/Item/GOSU/Set::Proxy(Instances) - Performs same action as double clicking component to trurn everu instance to proxy
                              Cheers!
                                renderiza
                                GOSU v1.0.9 Released!
                                Made compatible with Extension Warehouse is rules.
                                  smicha
                                  Thanks Rafa for your effort. I am extremely busy at work now, but I'll test it for sure.
                                    renderiza
                                    [pre:300fuwkg]Authors:: Renderiza
                                    Plugin Name:: GOSU
                                    Version:: 1.1.0
                                    Date:: 9/26/2013
                                    Cost:: Free[/pre:300fuwkg]
                                    GOSU v1.1.0 is now available for download.
                                    %(#909090)[What is new:
                                    • Smaller web-dialog
                                    • Cursor will start white and if hovers over component that has an action ready it will turn green but if it has nothing then it will turn red.
                                    • Fixed tons of bugs]
                                      smicha
                                      Rafa, thanks for the update. I truly appreciate the plugin, especially for proxy features!
                                        smicha
                                        I have problems with assigning shortcuts. When I go to "window-preferences-shortcuts" I cannot find "edit/item/GOSU...". There is no such function displayed.
                                        Please help Rafa.
                                        smicha
                                          renderiza
                                          Please help Rafa.
                                          smicha
                                          I will add that option back soon. πŸ‘
                                            renderiza
                                            [pre:18kfhjcw]Authors:: Renderiza
                                            Plugin Name:: GOSU
                                            Version:: 1.1.1
                                            Date:: 10/21/2013
                                            Cost:: Free[/pre:18kfhjcw]
                                            GOSU v1.1.1 is now available for download.
                                            • Each function will be displayed in "window-preferences-shortcuts"
                                            • There is right click menu as well.]
                                            • 3 / 4
