    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 73.8k Views 16 Watching
      smicha
      Here is a problem: I assigned F3 to cline. When I press F3 and select a component nothing happens. When I select a single component and press F3 it works but when I want to remove cline - no way to do it with F3. I also cannot convert all same components to clines with F3.
      Thanks for your effort Rafael.
        smicha
        • renderizaR Offline
          renderiza
          The way Set:: Proxy(cline) works at the moment is that it only can handle multiple component objects at the same time if they all are part of the same instant group.
          Also you can't assign same shortcut key to both Set::Proxy(cline) and No::Proxy(Cline) because they are consider two different actions. This mean you can set one to 'F3' and the other to 'F4' for example.
          You can't convert all same instances like you did by double clicking using the web dlg with the shortcut key because that is a different action that is only triggered with double clicking. To make that work using a key shortcut I will have to assign a context tool specially for that task, if I do this you can't assign it to same shortcut key as 'F3' or 'F4'. It will have to be 'F5' and if you want to turn them all back 'F6' πŸ˜•.
          I know this is getting complicated to explain but I hope you got what I was saying. I will try to see if I can make it so that you use one shortcut key but at the moment I don't know how.
          Cheers! πŸ‘
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            renderiza
            Ok just solved how you can use same shortcut to toggle Proxy on & off so that you can use F3 for both actions (this was simpler that I thought to solve 😳).
            To make every instance of that component you selected turn proxy on & off like it did with double click action another key might be needed (F4) but it will be the same key to turn everything on or off so its good.
            As to work a way to turn all selected components to proxy even though the are not same instance of each other that might be more tricky so it will take longer to figure out...at least for me. πŸ˜„
            Anyways the new Gosu version bet "Bugs" fixed will be release soon.
              smicha
              I'll test it ASAP Rafa and let you know. Thank for such fast correction.
                renderiza
                GOSU v1.0.8 Released!
                [highlight=#bfff00:2kvzuda1]1.0.8:: 4/30/2013[/highlight:2kvzuda1]
                • Set:: Proxy(instances) - Added this to context menu
                • Set:: Proxy(box and cline) now use the same action to turn on & off (this is useful to set shortcut key)
                Edit/Item/GOSU/Set::Proxy(Box) - Uses same action for turning proxy on & off now
                Edit/Item/GOSU/Set::Proxy(Cline) - Uses same action for turning proxy on & off now
                Edit/Item/GOSU/Set::Proxy(Instances) - Performs same action as double clicking component to trurn everu instance to proxy
                Cheers!
                  renderiza
                  GOSU v1.0.9 Released!
                  Made compatible with Extension Warehouse is rules.
                    smicha
                    Thanks Rafa for your effort. I am extremely busy at work now, but I'll test it for sure.
                      renderiza
                      [pre:300fuwkg]Authors:: Renderiza
                      Plugin Name:: GOSU
                      Version:: 1.1.0
                      Date:: 9/26/2013
                      Cost:: Free[/pre:300fuwkg]
                      GOSU v1.1.0 is now available for download.
                      %(#909090)[What is new:
                      • Smaller web-dialog
                      • Cursor will start white and if hovers over component that has an action ready it will turn green but if it has nothing then it will turn red.
                      • Fixed tons of bugs]
                        smicha
                        Rafa, thanks for the update. I truly appreciate the plugin, especially for proxy features!
                          smicha
                          I have problems with assigning shortcuts. When I go to "window-preferences-shortcuts" I cannot find "edit/item/GOSU...". There is no such function displayed.
                          Please help Rafa.
                          smicha
                            renderiza
                            Please help Rafa.
                            smicha
                            I will add that option back soon. πŸ‘
                              renderiza
                              [pre:18kfhjcw]Authors:: Renderiza
                              Plugin Name:: GOSU
                              Version:: 1.1.1
                              Date:: 10/21/2013
                              Cost:: Free[/pre:18kfhjcw]
                              GOSU v1.1.1 is now available for download.
                              • Each function will be displayed in "window-preferences-shortcuts"
                              • There is right click menu as well.]
                                smicha
                                Works like a charm! 😍
                                  smicha
                                  Help Rafa! - please make it work under 2014.
                                    What makes you think it doesn't already work in v2014 ?
                                    I just installed it from the PluginStore and it seems fine πŸ˜•
                                      smicha
                                      TIG,
                                      my fault. I tested it on a group instead of a component. It works like a charm.
                                        mxd1970
                                        It's a pity that it doesn't work on Mac.
                                          cleavermike
                                          Is it not possible to use GOSU in Sketchup Viewer or am I doing something wrong? I am setting components with a URL which works great with Sketchup Pro but doesn't in Viewer.
                                          Mike
                                            Mr Timberdude
                                            Thanks for this, its a great tool! I use it on construction projects to link in structural drawings that are related to the item you are viewing. This works great when we keep our models on one computer, but if I transfer the model and files to another computer it won't stay linked to the files I selected before. Is there a way to go in a quickly change the file location maps? or a way to keep it linked when it gets loaded up to another computer? I hand over models to our guys building, so they can get a deeper understanding of the building.
                                            • 3 / 4
