[Plugin]Components Placer v1.2(Apr24,2013)
Hi,All.
I create Components Placer plugin.
Place the Components aligned like side by side easily.
###General disclaimer
###I MAKES NO GUARANTEE OF VALIDITY about this script.
###Please use this script at your own risk.
DONWLOAD:
Get the latest version from the PluginStore: http://sketchucation.com/resources/pluginstore?pln=Components_Placer
or AutoInstall from within SketchUp using the SketchUcation Tools@unknownuser said:
version1.0(First release)
UPDATE:Apr15,2013.
UPDATE:Apr24,2013.
Bugfix:Bounding Box lines reminds when Undo.
Improve:File selector by using html input type="file".
So the path including special character will work fine.
Improve:Select none in listbox when starting at first.Latest Version:
Great tool added to Plugin Store
great idea
but choosing a skp file in a folder with "select folder" doesn't bring the content of the folder on my computer
Hi,Rich!
The store is very helpfull for me.Hi,Glro!
I think the folder path you select including special character like non-alphabetical.
That is the very big problem of ruby in sketchup.thanks.
Tak
Just plain thank you for another super plugin
dtr
Remember seeing this not so long ago in youtube...I am glad you posted it!
Awesome features indeed!
Thanks. I like this.
@tak2hata said:
Hi,Rich!
you are right; it was a special character (è) problem... again
suggestion... a file browser, with 2 interactive windows, so that when you click on the folder, all the components inside the folder appear below in the second window...
only a suggestion, i don't even know if it possible to make it work this way
You can alos use Align and Distribute by Sdmitch!
I update this to version 1.2 in Apr24,2013.
Improve:Select none in listbox when starting at first.Thanks.
yes, special characters are not a problem anymore; thank you
the folder by default comes back to "Home" and the second folder direction is emptied each time you come back to using the plugin; the third window does contain the previous components; would it be possible to keep track also of the folders address and propose them by default?
Where is "Home" on the hard drive?
Hi,glro.
"Home" is Components list in the model.I will improve next update about Keep the folder from previous work.
Thanks.
Not work on Mac OS
Register LoginAdvertisement
