    [Plugin]Components Placer v1.2(Apr24,2013)
    13 Posts 8 Posters 20.5k Views 8 Watching
      glro
      great idea
      but choosing a skp file in a folder with "select folder" doesn't bring the content of the folder on my computer
        tak2hata
        Hi,Rich!
        The store is very helpfull for me.
        Hi,Glro!
        I think the folder path you select including special character like non-alphabetical.
        That is the very big problem of ruby in sketchup.
        thanks.
        by TAK2HATA
          dtrarch
          Tak
          Just plain thank you for another super plugin 👍
          dtr
          • renderizaR Offline
            renderiza
            Remember seeing this not so long ago in youtube...I am glad you posted it!
            Awesome features indeed! 👍
            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
            • srxS Offline
              srx
              Thanks. I like this. 👍
              www.saurus.rs
                glro
                @tak2hata said:
                Hi,Rich!
                Hi,Glro!
                thanks.
                you are right; it was a special character (è) problem... again
                suggestion... a file browser, with 2 interactive windows, so that when you click on the folder, all the components inside the folder appear below in the second window...
                only a suggestion, i don't even know if it possible to make it work this way
                  You can alos use Align and Distribute by Sdmitch! 😉
                    tak2hata
                    I update this to version 1.2 in Apr24,2013.
                    Bugfix:Bounding Box lines reminds when Undo.
                    Improve:File selector by using html input type="file".
                    So the path including special character will work fine.
                    Improve:Select none in listbox when starting at first.
                    Thanks.
                    by TAK2HATA
                      glro
                      Thanks.
                      yes, special characters are not a problem anymore; thank you
                      the folder by default comes back to "Home" and the second folder direction is emptied each time you come back to using the plugin; the third window does contain the previous components; would it be possible to keep track also of the folders address and propose them by default?
                      Where is "Home" on the hard drive?
                        tak2hata
                        Hi,glro.
                        "Home" is Components list in the model.
                        I will improve next update about Keep the folder from previous work.
                        Thanks.
                        by TAK2HATA
                          serpe
                          Not work on Mac OS 😢
