    Glass lighting modelling tips?
    Scheduled Pinned Locked Moved Organic Modelling
    18 Posts 7 Posters 11.1k Views 7 Watching
      mb976
      Hello,
      We are a glassblowing studio that focuses on pendant lighting. Recently we've been experimenting with visualisations in SketchUp but have been running into a few issues. Most likely this is due to our inexperience with the tools and techniques - so I'm wondering if anyone has any hints and tips. Here's what we do: http://www.rothschildbickers.com/products/
      For now we're really just after getting the geometry accurate, though in the long run we may be looking to do photorealistic renderings (probably with the Maxwell plugin). Some products are going to be easier than others of course, but we seem be struggling with the processing and file size in some attempts. Our aim is to use the models in sketch visuals during the design stages with architects & interior specifiers.
      We started out drawing a section and using the follow-me tool to revolve it. This then progressed with bezier splines but we are experiencing a lot of crashes (iMac with 2.4GHz Intel Core 2 Duo running 10.6.8 with 4GB SDRAM). Curviloft seems like it should work for this scenario and perhaps Artisan too with it's ability to sculpt a form.
      Specifically we are struggling to model the wavy, optic (vertical lines on the surface) glass and stamped metal forms on the Flora Pendant.
      http://www.rothschildbickers.com/wp-content/uploads/rothschild-bickers_flora-vintage-spindle.jpg
      • from left: Flora, Vintage, Spindle Pendant
      Any advice or tips would be greatly.
      Thanks.
        leminilab
        I'm always impressed to see real world hand/mouth-crafted objects! 😲
        Spindle Pendant is a fun one to model. I couldn't resist trying...
        Flora's glass may be achieved more easily with texturing rather than modelling...
        Unfortunately, I use Thea Render and can't help you with Maxwell as far as texturing goes...
        • "Live every day as if it were your last and then some day you'll be right."
        • "ThomThom rules!!!"
        • Rich O BrienR Online
          I think hard surface modelling is the best approach here.
          Lofting will get good results but controlling segments will give you headaches
            mb976
            @rich o brien said:
            [attachment=0:2l6ex1kh]<!-- ia0 -->Image 1.png<!-- ia0 -->[/attachment:2l6ex1kh]
            @RIch: Excuse my ignorance, but how exactly have you done that? Is that a follow me of a line around a 16 sided polygon followed by Subdivide & Smooth from Artisan Tools?
            Thanks.
              Lathed for 8 segment then inserted geometry where needed...
              ...as you can see the more you introduce the more control you get over the final result.
                leminilab
                Here's my attempt at your Spindle:
                  rspierenburg
                  And to think, modelling these lights is probably 1/1000th as hard as making them in real life. Very impressive.
                    Nice result πŸ‘
                    The more complicated lamp took less than time to model than the other one πŸ˜’
                    Though SU crunched some numbers before displaying a result
                      leminilab
                      A quick test render:
                      No doubt the true master is you for crafting these! πŸ‘ to you!
                      • pbacotP Offline
                        luscious! Rich are those all watertight (double-wall) forms?
                        Some nice designs-- should be great rendering your products with different lights.
                        Upgrade that Mac. Mark (get a new 8 core). You work deserves it.
                          Single walled Peter
                          But Thea has nice preset thick glass materials
                          If I get time ill do a screen cast. Busy with other stuff. But enjoyed taking time out to make these.
                          They are beautiful lamps you guys make.
                          • soloS Offline
                            solo
                            I guess I get the easy one.
                            Double thick glass.
                            http://www.solos-art.com
                              leminilab
                              No thickness for me, just a single sided mesh with clear glass material.
                              I added a studio IBL and Mr Pete Stoppel's studio and it's done!
                              I'm still amazed that you actually manufacture those!
                                mb976
                                Wow!! You guys can rock this stuff out so quickly, we struggle along for ages and end up with something that kind of looks like what we are after.
                                We are only very, very basic with sketchup, but are really enjoying the potential to communicate with our clients. Would love to see a bit more detail in how you chaps are getting to these results, are there any good resources for this kind of modelling. We are keen to get a good understanding of best practice etc.
                                Ideally we would like the objects to have a double wall as we probably won't be photo rendering very much and I guess this will give us the most realistic output from sketchup...
                                We are sort of getting some results out of artisan but have only just started using it, with the Vintage light is it best to model in the flat, pull up the concentric rings and then alter the points to determine the waves before using artisan...
                                Sorry for basic questions, we are better at glass blowing than 3d modelling...and thanks for the kind comments, much appreciated.
                                  The modeling isn't all that hard. It is probably related to workflow as to why you are not getting quick results.
                                  There's no real tuts out there because the shape requires a basic understand of hard surface modeling. Once you learn the basics then skies the limit.
                                  You'll also find people tend not to share the steps because when you show an example it can lead to 50 other questions and time is money for a lot folks.
                                  • soloS Offline
                                    solo
                                    Attached is the proxy, subdivide and smooth as needed, get an idea of how the proxy looks.
                                    glass thing.skp
                                    • bazB Offline
                                      baz
                                      Hi Mark, love your work.
                                      You might want to check out this thread...
                                      404 Not Found
                                      (sketchucation.com)
                                      ...lots of great examples of organic modelling inc. glass.
                                        mb976
                                        Thank you so much for your help chaps, it is really amazing to see how Sketchup has been redefined as a program, the organic modelling is exactly what we need!!
                                        The examples is the thread suggested by baz really give a newbie like me a great idea of how the proxy shape guides Artisan to create the curves...very, very interesting.
                                        We will keep on learning the hard modelling side so we have understanding and flexibility to create the proxy's we need, thanks again, you have all been very helpful.
