    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [Plugin] Canvas v1.1.3
    scheduled pinned locked moved Plugins
    98 Posts 31 Posters 71.6k Views 31 Watching
    loading-more-posts
    • oldest-to-newest
    • newest-to-oldest
    • most-votes
    reply
    • reply-as-topic
    guest-login-reply
    deleted-message
    • renderizaR Offline
      renderiza
      srx::
      Thank you
      cuttingedge::
      There is no parameter controls at the moment but its on my to do list.
      3dsmax9::
      Added RND_0_Menu.rb to Rar File...Thank you for pointing it out. πŸ‘
      Thanks for your suggestion I will look into it but in the mean time please check 'Repeat Copy' by Chris Fullmer here... http://sketchucation.com/forums/viewtopic.php?t=26117
      Krisidious::
      What makes Canvas unique is the constant copies you get without having to do multiple clicks.
      guanjin::
      I am glad you were able to resolve the issue. πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      one-reply-to-this-post last-reply-time reply quote 0
      • guanjinG Offline
        guanjin
        guanjin::
        I am glad you were able to resolve the issue. πŸ‘[/quote]
        Increase the size of the adjustment distance the better, some randomness, overlapping other components, will produce along the Z axis superimposed.
        I come from China, is to learn
        • sicksickisckS Offline
          sicksickisck
          hah nice tool! and work very fine for me :]
            renderiza
            Update RND_Canvas v1.0.2 Beta
            New::
            1.0.2 Beta:: 4/8/2013
            • Add:: Multiple -- Adds Multiple Groups or Components while holding left mouse button
            • Add:: Single -- Adds Single Groups or Components while holding left mouse button
            • Don't Add:: If pointer on top of face
            • Select:: Normal or Random Input Position
            http://sketchucation.com/forums/download/file.php?id=104057
            "Add:: On Edge" will be available on v1.0.3
            Note:
            Added new features that some of you were suggesting and if you have any more suggestions let me know.
            Now you can choose to add only one group or component per click use "Add:: Single".
            Also for people that want to avoid having groups or components overlaps use the "Don't Add:: If pointer on top of face".
            ::A tip:: When using "Don't Add:: If pointer on top of face" I suggest having the Group or Component Axis on center
            For adding some randomness while adding groups or components click :Select:: Random Input Position"
            That is it I hope you like the new features for "Canvas"! πŸ‘
            • guanjinG Offline
              guanjin
              New::
              Note:
              The so quickly update the functionality I want,Renderiza: Great, you're God.
              πŸ‘ 😍
                renderiza
                guanjin ::
                Thanks for your positive comment!
                Here is a Sneak Peak on next Canvas version 1.0.3 Beta!
                http://sketchucation.com/forums/download/file.php?id=104104&mode=view/rokbox.jpg
                Hope to release it soon and maybe add more features...again thanks!
                • guanjinG Offline
                  guanjin
                  guanjin ::
                  If you modify the options selective disappearance,and then activate the tool view window space-saving, thank you.
                  Thanks again!
                  I hope the first to try new brushes!
                  • 3 Offline
                    3dsmax9
                    the update ils so cool thank you, the next update look great it will help me a lote thank you so much for this Renderiza.
                      renderiza
                      Canvas version 1.0.3 Beta - Released today!!!
                      Hi, hope this new version is well accepted and sorry the Add:: On Shadow is not available in this version but hopefully the next one.
                      Again any feedback & advise is more than welcome. πŸ‘
                      3dsmax9::
                      Thanks for the feedback I really appreciate it!
                      guanjin::
                      I modified the code so that if you don't have component or group selected the window dlg will still be there after warning message. Thanks!
                      • PixeroP Offline
                        Pixero
                        Thanks, I would like to see both fixed and randomized scale and rotation withing bounds.
                        Also to be able to select where it should be scaled and rotated from. Component axis isnt Always where it ought to be. See Chris Fullmer's Rotate and scale multiple for a good example.
                        • 3 Offline
                          3dsmax9
                          thank you very much for this update these stuff is cool, here's some proposition for this great script:
                          . it will be great if the dialog box remeber the last position and setting that we give to it so that wen we reopen it it stais in that possition with the same setting that we used last (I am sorry for my bad english).
                          . wen we use the add on vertex it will be cool if we can see the vertex that we will be inserte the groupe or comp like wen we use the move/copy tool.
                          . a description video will be very helpfull.
                          AND THANK YOU VERY MUCH I THINK THAT THIS TOOLS WILL BE ONE OF THE MUST USED IN SKETCHUP FORoM NOW ON i now i will be using it a lot THANK'S again.
                            renderiza
                            Bug Fixed in Canvas
                            I was receiving a Warning Prompt to select a Group or Component even if Group was selected so I fixed that in v1.0.4.
                            This suggested feature sounds really useful and will try my best to make it happen even though I am little busy with work.
                            I found a tutorial on how to do this with cookies so hope to make it happen soon
                            I will look into how to do this...thanks for the idea.
                            Reason why I have yet to make a video is that plugin is changing in fast paste so I am afraid to spend time make video when plugin will be different soon but soon I will find time to do one.
                            Again Thanks!
                            • guanjinG Offline
                              guanjin
                              (1) whether selecting the components out of the Options dialog box, select the function dialog box will disappear automatically affect the visibility of the window.
                              (2)Select the function to maintain the next default.
                              (3)Can achieve a variety of different components replication, scaling.
                              Thank you!Do not mind if I just fantasy! πŸ‘ πŸ‘ πŸ‘[/quote]
                              • guanjinG Offline
                                guanjin
                                • guanjinG Offline
                                  guanjin
                                  • olisheaO Offline
                                    olishea
                                    Well done Rafael, looking forward to the plugin's progression.
                                    Thank you very much.
                                    oli
                                      Anton_S
                                      Nice plugin!! πŸ‘
                                      A suggestion:
                                      Add start and commit operation for each click, so that I woudn't have to press ctrl-z for each added entity. πŸ˜’
                                        driven
                                        Bug Fixed in Canvas
                                        this does it...
                                        ## @@canvas_dlg.set_position (70,95) ;
                                        john
                                          renderiza
                                          Thank you!Do not mind if I just fantasy! πŸ‘**
                                          Thanks for the suggestions they really help. πŸ‘
                                          Thank you very much.**
                                          Thanks!
                                          **@anton_s said:
                                          Nice plugin!! πŸ‘
                                          A suggestion:
                                          Add start and commit operation for each click, so that I woudn't have to press ctrl-z for each added entity. πŸ˜’**
                                          I have tried to enclose some code with start and commit operations but even though its assigned name appears as a undo option it only does it one step at a time. 😞
                                          **@driven said:
                                          Bug Fixed in Canvas
                                          this does it...
                                          john**
                                          What I meant was for plugin to remember form values like check boxes for example
                                            Anton_S
                                            Oh, just add model.start_operation(...) at the beginning of onLButtonDown method, and add model.commit_operation in the onLButtonUp method. After that, it must work πŸ˜„
                                            Btw, open Ruby Console and test your plugin; it has a bunch of tiny bugs πŸ’š
                                            • 2 / 5
                                            • first-post
                                              last-post
