    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 85.6k Views 31 Watching
    • renderizaR
      renderiza
      Canvas version 1.0.3 Beta - Released today!!!
      Hi, hope this new version is well accepted and sorry the Add:: On Shadow is not available in this version but hopefully the next one.
      Again any feedback & advise is more than welcome. πŸ‘
      3dsmax9::
      Thanks for the feedback I really appreciate it!
      guanjin::
      I modified the code so that if you don't have component or group selected the window dlg will still be there after warning message. Thanks!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • PixeroP
        Pixero
        Thanks, I would like to see both fixed and randomized scale and rotation withing bounds.
        Also to be able to select where it should be scaled and rotated from. Component axis isnt Always where it ought to be. See Chris Fullmer's Rotate and scale multiple for a good example.
          3dsmax9
          thank you very much for this update these stuff is cool, here's some proposition for this great script:
          . it will be great if the dialog box remeber the last position and setting that we give to it so that wen we reopen it it stais in that possition with the same setting that we used last (I am sorry for my bad english).
          . wen we use the add on vertex it will be cool if we can see the vertex that we will be inserte the groupe or comp like wen we use the move/copy tool.
          . a description video will be very helpfull.
          AND THANK YOU VERY MUCH I THINK THAT THIS TOOLS WILL BE ONE OF THE MUST USED IN SKETCHUP FORoM NOW ON i now i will be using it a lot THANK'S again.
          • renderizaR
            renderiza
            Bug Fixed in Canvas
            I was receiving a Warning Prompt to select a Group or Component even if Group was selected so I fixed that in v1.0.4.
            This suggested feature sounds really useful and will try my best to make it happen even though I am little busy with work.
            I found a tutorial on how to do this with cookies so hope to make it happen soon
            I will look into how to do this...thanks for the idea.
            Reason why I have yet to make a video is that plugin is changing in fast paste so I am afraid to spend time make video when plugin will be different soon but soon I will find time to do one.
            Again Thanks!
            • guanjinG
              guanjin
              (1) whether selecting the components out of the Options dialog box, select the function dialog box will disappear automatically affect the visibility of the window.
              (2)Select the function to maintain the next default.
              (3)Can achieve a variety of different components replication, scaling.
              Thank you!Do not mind if I just fantasy! πŸ‘ πŸ‘ πŸ‘[/quote]
              • guanjinG
                guanjin
                • guanjinG
                  guanjin
                  • olisheaO
                    olishea
                    Well done Rafael, looking forward to the plugin's progression.
                    Thank you very much.
                    oli
                      Anton_S
                      Nice plugin!! πŸ‘
                      A suggestion:
                      Add start and commit operation for each click, so that I woudn't have to press ctrl-z for each added entity. πŸ˜’
                        driven
                        Bug Fixed in Canvas
                        this does it...
                        ## @@canvas_dlg.set_position (70,95) ;
                        • renderizaR
                          renderiza
                          Thank you!Do not mind if I just fantasy! πŸ‘**
                          Thanks for the suggestions they really help. πŸ‘
                          Thank you very much.**
                          **@anton_s said:
                          Nice plugin!! πŸ‘
                          A suggestion:
                          Add start and commit operation for each click, so that I woudn't have to press ctrl-z for each added entity. πŸ˜’**
                          I have tried to enclose some code with start and commit operations but even though its assigned name appears as a undo option it only does it one step at a time. 😞
                          **@driven said:
                          Bug Fixed in Canvas
                          this does it...
                          john**
                          What I meant was for plugin to remember form values like check boxes for example
                            Anton_S
                            Oh, just add model.start_operation(...) at the beginning of onLButtonDown method, and add model.commit_operation in the onLButtonUp method. After that, it must work πŸ˜„
                            Btw, open Ruby Console and test your plugin; it has a bunch of tiny bugs πŸ’š
                            • renderizaR
                              renderiza
                              The Add::Multiple does not work under "onLButtonDown" but instead under "onMouseMove" which seems not to work well with model.start_operation & model.commit_operation.
                              I did test the model.start_operation & model.commit_operation with onLButtonDown and it worked but since you only add one object it doesn't need undo s that much.
                              Thanks for pointing out the bug at Ruby Console!...I have to learn to Debug! πŸ’š
                              • KrisidiousK
                                Krisidious
                                Kool stuff... great for landscaping.
                                By: Kristoff Rand
                                • renderizaR
                                  renderiza
                                  Released Canvas 1.0.5 Beta includes;
                                  1.0.5 Beta:: 4/15/2013
                                  * Changed Web Dialog 'Frames Per Second' from 1 fps to 5 fps
                                  * Added Cursor Point Ref
                                  * Tooltips on ip1
                                  * Add:: On Shadow
                                  Notes:
                                  The frame rate that updates the values of Web Dialog is now little bit more responsive since I changed the fps from 1 to 5.
                                  Also added a red point under cursor so that its easier to see where you are placing objects. And there is even a tool tip that display text to inform on what you are on.
                                  And finally thanks to TIG I was able to solve the Add:: On Shadow so that you can place objects only o shadow.
                                  Again thanks for feedback and hope to add new things in the future!
                                  Hi, I am glad you found a use for it!
                                  • renderizaR
                                    renderiza
                                    1.0.6 Beta:: 4/19/2013
                                    * Plugin is portable friendly now
                                    This update makes the plugin portable for people that don't use the default plugins folder.
                                    Thanks to thomthom for suggesting doing this. πŸ‘
                                    • CadFatherC
                                      CadFather
                                      Thanks Renderiza - a great plugin.
                                      1 question, is there anyway to avoid stacking objects on top of each other when free painting?
                                      • renderizaR
                                        renderiza
                                        The closes thing to address this is "Don't Add:: If pointer on top of face" check-mark but its suggested that the axis of the object is being use to pain is centered. Problem with the method I mentioned is that it only works if you are painting on empty surface and you might still have some staking here and there.
                                        I am still thinking to add a feature that solves this issue but until l then you might want to look at this...
                                        On http://sdmitch.blogspot.com/ there is a plugin called Component Check - Check for over-lap of given component removes one.
                                        Here is Direct link and video link...
                                        https://docs.google.com/file/d/0Bw8zdmaKDWIfNjgxYjAzNmYtNjQ0YS00ZTkwLThlYTMtNTMwZTFmNWZhZDJh/edit?pli=1
                                        Page Not Found
                                        Web word processing, presentations and spreadsheets
                                        (docs.google.com)
                                        Cheers! πŸ‘
                                        • CadFatherC
                                          CadFather
                                          I see.. well it is quite amazing already - one of those 'unleash the creative' plugin (and thanks for the links). πŸ‘
                                          • renderizaR
                                            renderiza
                                            Canvas v1.0.8 Released!
                                            Hi, this is small update to make plugin compatible with Extension Warehouse.
                                            • 2 / 5
