    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 85.6k Views 31 Watching
      3dsmax9
      in the RND_Canvas v1.0.1 Beta.rar file this file is missing RND_0_Menu.rb so download the RND_0_Menu.rbz guanjin
      this is very cool but can you make it add a comp or groupe with just one click every time you click one time an component will be added it will be very usful.
      • KrisidiousK
        Krisidious
        what is the difference between this and spray paint can?
        By: Kristoff Rand
        • guanjinG
          guanjin
          Or can not be loaded, the same problem! 😞 😞
          • guanjinG
            guanjin
            • guanjinG
              guanjin
              Issue is resolved, I reinstall sketchup8, and then test the normal use, thank you, it is tough!
              • renderizaR
                renderiza
                srx::
                Thank you
                cuttingedge::
                There is no parameter controls at the moment but its on my to do list.
                3dsmax9::
                Added RND_0_Menu.rb to Rar File...Thank you for pointing it out. πŸ‘
                Thanks for your suggestion I will look into it but in the mean time please check 'Repeat Copy' by Chris Fullmer here... http://sketchucation.com/forums/viewtopic.php?t=26117
                Krisidious::
                What makes Canvas unique is the constant copies you get without having to do multiple clicks.
                guanjin::
                I am glad you were able to resolve the issue. πŸ‘
                [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                • guanjinG
                  guanjin
                  guanjin::
                  I am glad you were able to resolve the issue. πŸ‘[/quote]
                  Increase the size of the adjustment distance the better, some randomness, overlapping other components, will produce along the Z axis superimposed.
                  • sicksickisckS
                    sicksickisck
                    hah nice tool! and work very fine for me :]
                    • renderizaR
                      renderiza
                      Update RND_Canvas v1.0.2 Beta
                      New::
                      1.0.2 Beta:: 4/8/2013
                      • Add:: Multiple -- Adds Multiple Groups or Components while holding left mouse button
                      • Add:: Single -- Adds Single Groups or Components while holding left mouse button
                      • Don't Add:: If pointer on top of face
                      • Select:: Normal or Random Input Position
                      http://sketchucation.com/forums/download/file.php?id=104057
                      "Add:: On Edge" will be available on v1.0.3
                      Note:
                      Added new features that some of you were suggesting and if you have any more suggestions let me know.
                      Now you can choose to add only one group or component per click use "Add:: Single".
                      Also for people that want to avoid having groups or components overlaps use the "Don't Add:: If pointer on top of face".
                      ::A tip:: When using "Don't Add:: If pointer on top of face" I suggest having the Group or Component Axis on center
                      For adding some randomness while adding groups or components click :Select:: Random Input Position"
                      That is it I hope you like the new features for "Canvas"! πŸ‘
                      • guanjinG
                        guanjin
                        New::
                        Note:
                        The so quickly update the functionality I want,Renderiza: Great, you're God.
                        πŸ‘ 😍
                        • renderizaR
                          renderiza
                          guanjin ::
                          Thanks for your positive comment!
                          Here is a Sneak Peak on next Canvas version 1.0.3 Beta!
                          http://sketchucation.com/forums/download/file.php?id=104104&mode=view/rokbox.jpg
                          Hope to release it soon and maybe add more features...again thanks!
                          • guanjinG
                            guanjin
                            guanjin ::
                            If you modify the options selective disappearance,and then activate the tool view window space-saving, thank you.
                            Thanks again!
                            I hope the first to try new brushes!
                              3dsmax9
                              the update ils so cool thank you, the next update look great it will help me a lote thank you so much for this Renderiza.
                              • renderizaR
                                renderiza
                                Canvas version 1.0.3 Beta - Released today!!!
                                Hi, hope this new version is well accepted and sorry the Add:: On Shadow is not available in this version but hopefully the next one.
                                Again any feedback & advise is more than welcome. πŸ‘
                                3dsmax9::
                                Thanks for the feedback I really appreciate it!
                                guanjin::
                                I modified the code so that if you don't have component or group selected the window dlg will still be there after warning message. Thanks!
                                • PixeroP
                                  Pixero
                                  Thanks, I would like to see both fixed and randomized scale and rotation withing bounds.
                                  Also to be able to select where it should be scaled and rotated from. Component axis isnt Always where it ought to be. See Chris Fullmer's Rotate and scale multiple for a good example.
                                    3dsmax9
                                    thank you very much for this update these stuff is cool, here's some proposition for this great script:
                                    . it will be great if the dialog box remeber the last position and setting that we give to it so that wen we reopen it it stais in that possition with the same setting that we used last (I am sorry for my bad english).
                                    . wen we use the add on vertex it will be cool if we can see the vertex that we will be inserte the groupe or comp like wen we use the move/copy tool.
                                    . a description video will be very helpfull.
                                    AND THANK YOU VERY MUCH I THINK THAT THIS TOOLS WILL BE ONE OF THE MUST USED IN SKETCHUP FORoM NOW ON i now i will be using it a lot THANK'S again.
                                    • renderizaR
                                      renderiza
                                      Bug Fixed in Canvas
                                      I was receiving a Warning Prompt to select a Group or Component even if Group was selected so I fixed that in v1.0.4.
                                      This suggested feature sounds really useful and will try my best to make it happen even though I am little busy with work.
                                      I found a tutorial on how to do this with cookies so hope to make it happen soon
                                      I will look into how to do this...thanks for the idea.
                                      Reason why I have yet to make a video is that plugin is changing in fast paste so I am afraid to spend time make video when plugin will be different soon but soon I will find time to do one.
                                      Again Thanks!
                                      • guanjinG
                                        guanjin
                                        (1) whether selecting the components out of the Options dialog box, select the function dialog box will disappear automatically affect the visibility of the window.
                                        (2)Select the function to maintain the next default.
                                        (3)Can achieve a variety of different components replication, scaling.
                                        Thank you!Do not mind if I just fantasy! πŸ‘ πŸ‘ πŸ‘[/quote]
                                        • guanjinG
                                          guanjin
                                          • guanjinG
                                            guanjin
                                            • 2 / 5
