    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 76.7k Views 31 Watching
    • renderizaR Offline
      renderiza
      Update RND_Canvas v1.0.2 Beta
      New::
      1.0.2 Beta:: 4/8/2013
      • Add:: Multiple -- Adds Multiple Groups or Components while holding left mouse button
      • Add:: Single -- Adds Single Groups or Components while holding left mouse button
      • Don't Add:: If pointer on top of face
      • Select:: Normal or Random Input Position
      http://sketchucation.com/forums/download/file.php?id=104057
      "Add:: On Edge" will be available on v1.0.3
      Note:
      Added new features that some of you were suggesting and if you have any more suggestions let me know.
      Now you can choose to add only one group or component per click use "Add:: Single".
      Also for people that want to avoid having groups or components overlaps use the "Don't Add:: If pointer on top of face".
      ::A tip:: When using "Don't Add:: If pointer on top of face" I suggest having the Group or Component Axis on center
      For adding some randomness while adding groups or components click :Select:: Random Input Position"
      That is it I hope you like the new features for "Canvas"! πŸ‘
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • guanjinG Offline
        guanjin
        New::
        Note:
        The so quickly update the functionality I want,Renderiza: Great, you're God.
        πŸ‘ 😍
          renderiza
          guanjin ::
          Thanks for your positive comment!
          Here is a Sneak Peak on next Canvas version 1.0.3 Beta!
          http://sketchucation.com/forums/download/file.php?id=104104&mode=view/rokbox.jpg
          Hope to release it soon and maybe add more features...again thanks!
          • guanjinG Offline
            guanjin
            guanjin ::
            If you modify the options selective disappearance,and then activate the tool view window space-saving, thank you.
            Thanks again!
            I hope the first to try new brushes!
            • 3 Offline
              3dsmax9
              the update ils so cool thank you, the next update look great it will help me a lote thank you so much for this Renderiza.
                renderiza
                Canvas version 1.0.3 Beta - Released today!!!
                Hi, hope this new version is well accepted and sorry the Add:: On Shadow is not available in this version but hopefully the next one.
                Again any feedback & advise is more than welcome. πŸ‘
                3dsmax9::
                Thanks for the feedback I really appreciate it!
                guanjin::
                I modified the code so that if you don't have component or group selected the window dlg will still be there after warning message. Thanks!
                • PixeroP Offline
                  Pixero
                  Thanks, I would like to see both fixed and randomized scale and rotation withing bounds.
                  Also to be able to select where it should be scaled and rotated from. Component axis isnt Always where it ought to be. See Chris Fullmer's Rotate and scale multiple for a good example.
                  • 3 Offline
                    3dsmax9
                    thank you very much for this update these stuff is cool, here's some proposition for this great script:
                    . it will be great if the dialog box remeber the last position and setting that we give to it so that wen we reopen it it stais in that possition with the same setting that we used last (I am sorry for my bad english).
                    . wen we use the add on vertex it will be cool if we can see the vertex that we will be inserte the groupe or comp like wen we use the move/copy tool.
                    . a description video will be very helpfull.
                    AND THANK YOU VERY MUCH I THINK THAT THIS TOOLS WILL BE ONE OF THE MUST USED IN SKETCHUP FORoM NOW ON i now i will be using it a lot THANK'S again.
                      renderiza
                      Bug Fixed in Canvas
                      I was receiving a Warning Prompt to select a Group or Component even if Group was selected so I fixed that in v1.0.4.
                      This suggested feature sounds really useful and will try my best to make it happen even though I am little busy with work.
                      I found a tutorial on how to do this with cookies so hope to make it happen soon
                      I will look into how to do this...thanks for the idea.
                      Reason why I have yet to make a video is that plugin is changing in fast paste so I am afraid to spend time make video when plugin will be different soon but soon I will find time to do one.
                      Again Thanks!
                      • guanjinG Offline
                        guanjin
                        (1) whether selecting the components out of the Options dialog box, select the function dialog box will disappear automatically affect the visibility of the window.
                        (2)Select the function to maintain the next default.
                        (3)Can achieve a variety of different components replication, scaling.
                        Thank you!Do not mind if I just fantasy! πŸ‘ πŸ‘ πŸ‘[/quote]
                        • guanjinG Offline
                          guanjin
                          • guanjinG Offline
                            guanjin
                            • olisheaO Offline
                              olishea
                              Well done Rafael, looking forward to the plugin's progression.
                              Thank you very much.
                              oli
                                Anton_S
                                Nice plugin!! πŸ‘
                                A suggestion:
                                Add start and commit operation for each click, so that I woudn't have to press ctrl-z for each added entity. πŸ˜’
                                  driven
                                  Bug Fixed in Canvas
                                  this does it...
                                  ## @@canvas_dlg.set_position (70,95) ;
                                    renderiza
                                    Thank you!Do not mind if I just fantasy! πŸ‘**
                                    Thanks for the suggestions they really help. πŸ‘
                                    Thank you very much.**
                                    **@anton_s said:
                                    Nice plugin!! πŸ‘
                                    A suggestion:
                                    Add start and commit operation for each click, so that I woudn't have to press ctrl-z for each added entity. πŸ˜’**
                                    I have tried to enclose some code with start and commit operations but even though its assigned name appears as a undo option it only does it one step at a time. 😞
                                    **@driven said:
                                    Bug Fixed in Canvas
                                    this does it...
                                    john**
                                    What I meant was for plugin to remember form values like check boxes for example
                                      Anton_S
                                      Oh, just add model.start_operation(...) at the beginning of onLButtonDown method, and add model.commit_operation in the onLButtonUp method. After that, it must work πŸ˜„
                                      Btw, open Ruby Console and test your plugin; it has a bunch of tiny bugs πŸ’š
                                        renderiza
                                        The Add::Multiple does not work under "onLButtonDown" but instead under "onMouseMove" which seems not to work well with model.start_operation & model.commit_operation.
                                        I did test the model.start_operation & model.commit_operation with onLButtonDown and it worked but since you only add one object it doesn't need undo s that much.
                                        Thanks for pointing out the bug at Ruby Console!...I have to learn to Debug! πŸ’š
                                        • KrisidiousK Offline
                                          Krisidious
                                          Kool stuff... great for landscaping.
                                          By: Kristoff Rand
                                            renderiza
                                            Released Canvas 1.0.5 Beta includes;
                                            1.0.5 Beta:: 4/15/2013
                                            * Changed Web Dialog 'Frames Per Second' from 1 fps to 5 fps
                                            * Added Cursor Point Ref
                                            * Tooltips on ip1
                                            * Add:: On Shadow
                                            Notes:
                                            The frame rate that updates the values of Web Dialog is now little bit more responsive since I changed the fps from 1 to 5.
                                            Also added a red point under cursor so that its easier to see where you are placing objects. And there is even a tool tip that display text to inform on what you are on.
                                            And finally thanks to TIG I was able to solve the Add:: On Shadow so that you can place objects only o shadow.
                                            Again thanks for feedback and hope to add new things in the future!
                                            Hi, I am glad you found a use for it!
                                            • 2 / 5
