    [Plugin]Extend Trim Faces.rb(Mar27,2013.)
    28 Posts 19 Posters 49.9k Views 19 Watching
      Ben Ritter
      Awesome. Thank you again for sharing the fruits of your talent.
      • sumasterS Offline
        sumaster
        I am using this plugin every day and I have some difficulty in a single selection. Each edge select and click one surface, it's wasting modeling time can you change single click to multiple edges selection or viewport selections. . . .
        Selection
        Thank you,
        SUmaster
        • JQLJ Offline
          JQL
          SU master you could do that easily with the move tool on the very selection you have. Why don't you try?
          www.casca.pt
          Visit us on facebook!
          • sumasterS Offline
            sumaster
            Hello JQL,
            Yes, you are right. But when you find a triangular shape wall.
            Triangular wall
            And when I move current selections, then the result is below. . .
            Move Selections
            But I want this result. . . . .
            want Result
            Thank you,
            SUmaster
            • pbacotP Offline
              Yes, that is only an example. And what if some of the faces to be moved are not aligned with others? The move function wouldn't help speed things up. I could see how this would be helpful. This tool looks to be a more specific version of some of the TIG's Extrusion tools ( extrude edges to face), which can move multiple disconnected edges. Some version of either of these tools really belongs in the basic SU toolbox.
                My snappily named 'ExtrudeEdgesByVectorToObject' would take all of the selected edges and moved their vertices along a picked vector stopping at the end of the vector OR the first face[s] that were met it the vector passes through some intervening object[s]...
                http://sketchucation.com/pluginstore?pln=ExtrudeTools
                http://sketchucation.com/plugin/1103-extrudetools for feedback link...
                See near the end of the movie of an example of its simpler sibling 'ExtrudeEdgesByVector'...
                • sumasterS Offline
                  sumaster
                  yes TIG sir right i use this but when ExtrudeEdgesByVectorToObject complete operation extruded edge loop not fill means not create face
                  Thank you,
                  SUmaster
                  • V Offline
                    vualua9
                    Cám ơn bạn nhiều ! Một công cụ có nhiều tiện ích. 👍 ➡
                    • 2 / 2
