    [Plugin]Extend Trim Faces.rb(Mar27,2013.)
    28 Posts 19 Posters 54.6k Views 19 Watching
    • T
      tak2hata
      @dem said:
      Thanks! Great plugin! But one nuance. Does not always get on the right plane when I click near the edge. Is it difficult to make the backlight of planes when cursor is on the small distance near the edge?)
      Hi,dem.
      I think it difficult.
      But I want it, too.
      I will consider it well.
      Thanks All!
      by TAK2HATA
      • I
        ishining
        very easy to use, thks
          rv1974
          tak2hata, is it possible to add those standard SU\Acad selection options:
          with Shift- select additional areas to be stretched
          with Alt- DEselect affected areas
          with Cnrl- precisely select or deselect (Cnrl+Alt) separate points.
          Thanks.
          • B
            Ben Ritter
            Awesome. Thank you again for sharing the fruits of your talent.
            • sumasterS
              sumaster
              I am using this plugin every day and I have some difficulty in a single selection. Each edge select and click one surface, it's wasting modeling time can you change single click to multiple edges selection or viewport selections. . . .
              Selection
              Thank you,
              SUmaster
              • JQLJ
                JQL
                SU master you could do that easily with the move tool on the very selection you have. Why don't you try?
                www.casca.pt
                Visit us on facebook!
                • sumasterS
                  sumaster
                  Hello JQL,
                  Yes, you are right. But when you find a triangular shape wall.
                  Triangular wall
                  And when I move current selections, then the result is below. . .
                  Move Selections
                  But I want this result. . . . .
                  want Result
                  Thank you,
                  SUmaster
                  • pbacotP
                    Yes, that is only an example. And what if some of the faces to be moved are not aligned with others? The move function wouldn't help speed things up. I could see how this would be helpful. This tool looks to be a more specific version of some of the TIG's Extrusion tools ( extrude edges to face), which can move multiple disconnected edges. Some version of either of these tools really belongs in the basic SU toolbox.
                      My snappily named 'ExtrudeEdgesByVectorToObject' would take all of the selected edges and moved their vertices along a picked vector stopping at the end of the vector OR the first face[s] that were met it the vector passes through some intervening object[s]...
                      http://sketchucation.com/pluginstore?pln=ExtrudeTools
                      http://sketchucation.com/plugin/1103-extrudetools for feedback link...
                      See near the end of the movie of an example of its simpler sibling 'ExtrudeEdgesByVector'...
                      • sumasterS
                        sumaster
                        yes TIG sir right i use this but when ExtrudeEdgesByVectorToObject complete operation extruded edge loop not fill means not create face
                        Thank you,
                        SUmaster
                        • V
                          vualua9
                          Cám ơn bạn nhiều ! Một công cụ có nhiều tiện ích. 👍 ➡
                          • 2 / 2
