    [Plugin]Extend Trim Faces.rb(Mar27,2013.)
    28 Posts 19 Posters 54.6k Views 19 Watching
    • I
      ishining
      very easy to use, thks
        rv1974
        tak2hata, is it possible to add those standard SU\Acad selection options:
        with Shift- select additional areas to be stretched
        with Alt- DEselect affected areas
        with Cnrl- precisely select or deselect (Cnrl+Alt) separate points.
        Thanks.
        • B
          Ben Ritter
          Awesome. Thank you again for sharing the fruits of your talent.
          • sumasterS
            sumaster
            I am using this plugin every day and I have some difficulty in a single selection. Each edge select and click one surface, it's wasting modeling time can you change single click to multiple edges selection or viewport selections. . . .
            Selection
            Thank you,
            SUmaster
            • JQLJ
              JQL
              SU master you could do that easily with the move tool on the very selection you have. Why don't you try?
              www.casca.pt
              Visit us on facebook!
              • sumasterS
                sumaster
                Hello JQL,
                Yes, you are right. But when you find a triangular shape wall.
                Triangular wall
                And when I move current selections, then the result is below. . .
                Move Selections
                But I want this result. . . . .
                want Result
                Thank you,
                SUmaster
                • pbacotP
                  Yes, that is only an example. And what if some of the faces to be moved are not aligned with others? The move function wouldn't help speed things up. I could see how this would be helpful. This tool looks to be a more specific version of some of the TIG's Extrusion tools ( extrude edges to face), which can move multiple disconnected edges. Some version of either of these tools really belongs in the basic SU toolbox.
                    My snappily named 'ExtrudeEdgesByVectorToObject' would take all of the selected edges and moved their vertices along a picked vector stopping at the end of the vector OR the first face[s] that were met it the vector passes through some intervening object[s]...
                    http://sketchucation.com/pluginstore?pln=ExtrudeTools
                    http://sketchucation.com/plugin/1103-extrudetools for feedback link...
                    See near the end of the movie of an example of its simpler sibling 'ExtrudeEdgesByVector'...
                    • sumasterS
                      sumaster
                      yes TIG sir right i use this but when ExtrudeEdgesByVectorToObject complete operation extruded edge loop not fill means not create face
                      Thank you,
                      SUmaster
                      • V
                        vualua9
                        Cám ơn bạn nhiều ! Một công cụ có nhiều tiện ích. 👍 ➡
                        • 2 / 2
