    Reversed text
    layout
    11 Posts 7 Posters 1.1k Views 7 Watching
    • emerald15E Offline
      emerald15
      Can anyone tell me if there is an easy way to flip all the text notes on a plan from the left to the right? I have a plan I have been asked to reverse, left to right. Its not problem to reverse the drawing, but if I select all the notes & flip them, their positions are corrected but the the text is reversed.
      I have already amended these manually, however, my client now wants the corrected plan reversed back again! Is there a short cut!?
        Place the rotation pivot at the center of the page
        rotate the selected text boxes with the pivot
        flip top to bottom
        flip left to right
          emerald15
          I tried that Rich - I still have backward text unless I flip each label individually... time consuming. i was hoping I could flip all the positions simultaneously without flipping the actual text backward.
            It works for me but I could be missing the exact problem here....
            Did you try selecting everything and doing a negative scale -1?
              ArCAD-UK
              No easy solution other than rt-clk -> flip on each text block after flipping the whole drawing. A prime example where you just have to get your head down and get on with it until we get Ruby in LO.
              There may be a moral to the story - Make regular backups and consider creating a new file before carrying out any major revisions.
              • pbacotP Offline
                The old days of backside (diazo) printing are gone. The text shouldn't do that, you should have to have a ruby to MAKE IT go backwards. LO shortcoming.
                • FrederikF Offline
                  Frederik
                  Another great example why the guys (and girls πŸ˜‰ ) should implement the Ruby API in next version... πŸ˜„
                  If some of the ruby gurus was able to code a little for LO, I'm sure we would see many things improved... πŸ˜‰
                  Cheers
                  Kim Frederik
                    ArCAD-UK
                    I think you are right Peter, the odds are that when you flip things about you would like the text to retain its justification and orientation although there may be ocassions when you want reversed text but that could best be handled through the attribute box. One for the 2013 wishlist?
                    • utilerU Offline
                      utiler
                      Always save a copy of your drawing before making changes. Nothing worst than a client saying they want something changed only to change their mind and go back to the last idea...
                      on reversing text; as everyone said there is not easy way currently.
                      Just Curious...
                        emerald15
                        Thanks for the advice everyone. Yes, believe me I have saved all previous versions (we got up to version 'M' on this project last year)! However, with the inclusion of amendments & un-expected plan re-scaling, etc. using the previous set of notes isn't idea either. Ah well...!
                        • RichardR Offline
                          Richard
                          Yeah there is no easy way. Though at least you can setup a flip shortcut! flip all the text to the opposite then select each and flip.
                          BUILTBRAND.COM.AU
