    Wrapping 2D drawing on a cylinder?
    19 Posts 8 Posters 1.9k Views 8 Watching
      Tyler
      I am trying to wrap a 2D drawing around a cylinder.
      Preferably, I'd like to force the 2D drawing to stretch to match the cylinder's dimensions, if possible.
      Thanks in advance,
      Ty
        Seems Shape Bender will be the more easy ?
        • jeff hammondJ Offline
          jeff hammond
          except shapebender won't work on a closed curved (cylinder).. so there's more work involved then just running shapebender and that's that..
          you have to take out some of the circle then calculate that gap and separate it from the flat drawing you're trying to wrap.. then fill in the gap manually..
          dotdotdot
          • olisheaO Offline
            olishea
            UV tools? cylindrical projection? tweak in PS?
            oli
            • pbacotP Offline
              What's cylindrical projection?
                jeff hammond
                yeah.. i was thinking that stuff as well at first..
                but he's saying 2D drawing so it's likely he's wanting to wrap sketchup geometry around a cylinder
                dotdotdot
                • F Offline
                  Futurepast
                  Thats the way πŸ˜„ First make just a circle at about 40 segments, cut 1/2 of a segmant out. Use Chris's tool on a jpg anothing (have to explode the pic than re component it). It will bend. Close the Top and bottom. Grab one long side and drag it to the other to close. It fills in both ends so you can do what ever from there
                  • olisheaO Offline
                    olishea
                    in thomthom UV tools, there is a choice of cylindrical and spherical projection. It works very well for images.
                    Sorry yeah I thought he meant a PDF/image not actual geometry.
                    oli
                      Tyler
                      clarification - I am indeed going to be wrapping 2D Sketchup geometry (a tiled hexagon)on to a cylindrical surface which will actually be a vault, no a complete cylinder.
                      After some research, I came across Fredo's "Tools on Surface" - might that work?
                      • olisheaO Offline
                        olishea
                        shape bender, it will work just fine.
                        oli
                          jeff hammond
                          shapebender...
                          dotdotdot
                          • olisheaO Offline
                            olishea
                            Would love to see a shapebender that works on a closed loop.
                            oli
                            • gillesG Offline
                              gilles
                              Cut it in two parts.
                                Tyler
                                Great - looks like I'll see how shapebender works out. Wasn't sure if it manipulated 2D entities.
                                • olisheaO Offline
                                  olishea
                                  That's how I did the honeycomb lamp, it's just annoying πŸ˜†
                                  oli
                                    jeff hammond
                                    it'd be nice but then you run into the error (you know.. that one in that crazy long thread πŸ˜†)
                                    the halves won't go back together properly
                                    dotdotdot
                                      Of course yes! β˜€
                                      And if you make a tiny gap in your curve's circle you don't see it on the result! πŸ’š
                                      • W Offline
                                        willbuttrick
                                        Is this plugin compatible with MAC?
                                        • olisheaO Offline
                                          olishea
                                          yes
                                          oli
