    Wrapping 2D drawing on a cylinder?
    19 Posts 8 Posters 1.9k Views 8 Watching
    • T
      Tyler
      clarification - I am indeed going to be wrapping 2D Sketchup geometry (a tiled hexagon)on to a cylindrical surface which will actually be a vault, no a complete cylinder.
      After some research, I came across Fredo's "Tools on Surface" - might that work?
      • olisheaO
        olishea
        shape bender, it will work just fine.
        oli
        • jeff hammondJ
          shapebender...
          • olisheaO
            olishea
            Would love to see a shapebender that works on a closed loop.
            oli
            • gillesG
              gilles
              Cut it in two parts.
              • T
                Tyler
                Great - looks like I'll see how shapebender works out. Wasn't sure if it manipulated 2D entities.
                • olisheaO
                  olishea
                  That's how I did the honeycomb lamp, it's just annoying πŸ˜†
                  oli
                  • jeff hammondJ
                    it'd be nice but then you run into the error (you know.. that one in that crazy long thread πŸ˜†)
                    the halves won't go back together properly
                      Of course yes! β˜€
                      And if you make a tiny gap in your curve's circle you don't see it on the result! πŸ’š
                      • W
                        willbuttrick
                        Is this plugin compatible with MAC?
                        • olisheaO
                          olishea
                          yes
                          oli
