    Wrapping 2D drawing on a cylinder?
    19 Posts 8 Posters 1.9k Views 8 Watching
    • pbacotP
      What's cylindrical projection?
      • jeff hammondJ
        @olishea said:
        UV tools? cylindrical projection? tweak in PS?
        yeah.. i was thinking that stuff as well at first..
        but he's saying 2D drawing so it's likely he's wanting to wrap sketchup geometry around a cylinder
        • F
          Futurepast
          Seems Shape Bender will be the more easy ?
          except shapebender won't work on a closed curved (cylinder).. so there's more work involved then just running shapebender and that's that..
          you have to take out some of the circle then calculate that gap and separate it from the flat drawing you're trying to wrap.. then fill in the gap manually..
          Thats the way πŸ˜„ First make just a circle at about 40 segments, cut 1/2 of a segmant out. Use Chris's tool on a jpg anothing (have to explode the pic than re component it). It will bend. Close the Top and bottom. Grab one long side and drag it to the other to close. It fills in both ends so you can do what ever from there
          • olisheaO
            olishea
            in thomthom UV tools, there is a choice of cylindrical and spherical projection. It works very well for images.
            Sorry yeah I thought he meant a PDF/image not actual geometry.
            oli
            • T
              Tyler
              clarification - I am indeed going to be wrapping 2D Sketchup geometry (a tiled hexagon)on to a cylindrical surface which will actually be a vault, no a complete cylinder.
              After some research, I came across Fredo's "Tools on Surface" - might that work?
              • olisheaO
                olishea
                shape bender, it will work just fine.
                oli
                • jeff hammondJ
                  shapebender...
                  • olisheaO
                    olishea
                    Would love to see a shapebender that works on a closed loop.
                    oli
                    • gillesG
                      gilles
                      Cut it in two parts.
                      • T
                        Tyler
                        Great - looks like I'll see how shapebender works out. Wasn't sure if it manipulated 2D entities.
                        • olisheaO
                          olishea
                          That's how I did the honeycomb lamp, it's just annoying πŸ˜†
                          oli
                          • jeff hammondJ
                            it'd be nice but then you run into the error (you know.. that one in that crazy long thread πŸ˜†)
                            the halves won't go back together properly
                              Of course yes! β˜€
                              And if you make a tiny gap in your curve's circle you don't see it on the result! πŸ’š
                              • W
                                willbuttrick
                                Is this plugin compatible with MAC?
                                • olisheaO
                                  olishea
                                  yes
                                  oli
