    Artisan - Subdivide and Smooth causing problems
    7 Posts 4 Posters 583 Views 4 Watching
    • bunnyackB Offline
      bunnyack
      Hey forum,
      I was playing around with artisan trying to create the shape of a water drop. When using Artisans "Subdivide and Smooth" tool, I noticed it was causing a weird deformation in the results it gave me. I'll let the screenshots explain:
      This is the basic shape I was using.
      And this is what Artisan gives me, when finished.
      Does anybody have an idea as to what could be causing this? I'm a complete newbie to artisan, using it for the first time today.
      Thanks in advance,
      Kevin
      • dukejazzD Offline
        dukejazz
        Do you have a example jpg you working from
        Here one I found
        • bunnyackB Offline
          bunnyack
          Here one I found
          Nah, I was just playing around, no reference images πŸ˜„
            The faces that are 'causing problems' are ngons. A big no-no when subdividing.
            • HieruH Offline
              Hieru
              Tig's Splidonut is needed in this situation. You should apply it to all the flat donut-shaped surfaces.
              You could also benefit from using a simpler proxy - see here.
              www.davidhier.co.uk
              • bunnyackB Offline
                bunnyack
                Thank you so much, this did the trick.
                • HieruH Offline
                  Hieru
                  No problem πŸ‘
                  As Rich says you need to avoid n-gons and stick to quads and tris.
                  www.davidhier.co.uk
