    A question about editing material
    14 Posts 6 Posters 745 Views 6 Watching
    • hellnbakH Offline
      hellnbak
      I know that when you edit a JPG and save it, it loses some detail, a little more each time, but PNG is a lossless format, no matter how many changes you make and how many times you save it, it loses no information. I've heard recommendations that textures should be imported as PNG's, and only after you are sure all editing of that texture is done you should change it to JPG, (to minimize file size). That makes sense to me.
      However....I can't seem to figure out how to do that. After I click on "Edit Texture Image" and open the texture in one of my graphics programs (depending on what I'm going to do with the texture) with the intention of only changing the PNG to JPG and saving it back into SU, things come to a grinding halt.
      The only option for changing the format of the image to JPG is to use "save as", and choose JPG. But, after I do that, what? I cannot then just click on "save" as I normally would after I've made changes to the texture, that option is greyed out.
      I've tried opening the saved JPG version in the graphics program, copying and pasting it over the PNG, deleting the PNG, and then saving it back to the model, but that doesn't change the file size so I'm assuming it, for whatever reason, is still saving it as a PNG.
      Is this making any sense at all? I'm trying to provide enuf information so that anyone reading this can maybe provide some help without having to ask a bunch of questions. But please, feel free to ask questions.
      I know I'm probably going about this in the wrong way, but that's why I'm posting this question.
      I also know this is probably one of those things that is simple beyond belief and that I'm going to feel real dumb, but I'm getting used to that.
        As far as I can see, the process would involve saving the edited material image as a JPG and then importing that as a texture and replacing the PNG. I guess I don't bother with that in my models, though. I just leave the PNG files. You might reduce the file size some by exchanging the uncompressed image for a compressed one but if the material is that good, why degrade it by compressing it?
        • hellnbakH Offline
          hellnbak
          Jeez, there's got to be an easier way. I mean, importing the JPG texture and trying to get it positioned and lined up perfectly like the PNG was, that's a real pain.
          As far as leaving it as a PNG, when you're talking about 50 or 100 textures, the size difference really adds up quickly. And if you (somehow) do replace the PNG with a JPG, as long as you don't make any changes to it and re-save it, the quality will be almost the same as the PNG.
          Or is my logic flawed?
            Well, I understand you have large numbers of materials but I don't see how you'll reduce file size much without degrading the images you are using. What I've seen of your work, I would think you wouldn't want to lose any image quality.
            • hellnbakH Offline
              hellnbak
              But up to now I've always used JPG's, avoiding PNG's entirely, and have edited and re-saved them numerous times. This has to have degraded the quality of the images, there's just no way to avoid that with JPG's. A PNG converted to JPG can save 40% or more, and like I said when you're dealing with the number of textures I use in most of my models it can really add up.
              Although maybe if you haven't noticed the quality of my JPG textures I shouldn't worry too much and just carry on.
              • Chris FullmerC Offline
                Well, there might be a plugin that does what you want. There are a few good material plugins. If not, I don't think it would be terribly difficult to make, or take an existing plugin and tweak it.
                Why does file size matter? A 40% savings is a 10mb file down to a 6mb file. 100 down to 60, etc. It just doesn't strike me as a huge deal in the grand scheme of things if you have a big hard drive.
                Editing and saving jpgs repeatedly will degrade them, but it is fairly trivial, unless you are saving them with reduced quality. I would recommend never doing that in any workflow ever, personally. Not ever. (ok, I do it occasionally when I'm sending a series of draft images via email and I know the person on the other end is looking at them on their phone and really doesn't care what they look like).
                All my Plugins I've written
                  Crunch the .png with PNGgaunlet.
                  • hellnbakH Offline
                    hellnbak
                    Hi Chris
                    No, hard drive space is not an issue (I have seven hard drives hooked up to this computer).
                    I suppose this may harken back to when I was using every trick in the book to keep my file size below the 10mb limit to post my models on the Warehouse. I don't use the Warehouse anymore, but the mentality is still there.
                    Still, SU can handle a 40mb model better than a 60mb model. And I like to use textures, a lot of them, so they make up a large part of my models. A forty percent reduction in the size of those textures would mean a lot.
                    Maybe I'm making too much of this, but like everyone else here I am always trying to improve the quality of my models, and that includes the quality of my textures.
                    As always, if there is a flaw in my logic please let me know.
                    • hellnbakH Offline
                      hellnbak
                      Wow, I didn't think PNG files could be compressed, so I never searched for anything like that.
                      I gave PNG Gauntlet a test run, and here are the results
                      I carefully compared the before and after photos, and could discern no difference at all.
                      The process took almost four minutes, probably because I was using the settings for maximum compression. But since I won't be using it to compress entire folders of PNG photos, only those that I will be using for textures, that won't be a factor.
                      I'm going to use this for a while and see if any problems crop up. If not, I will be using PNG textures from now on.
                      Many thanks! 😄
                        It doesn't just crunch .png files...
                        But glad it helped
                        Sent from my iPad
                          shelleygale
                          Hi. I've just (finally) upgraded to SU Pro 2016. After migrating my Materials from SU 2015 to 2016 some textures are not giving me the option to edit in an external program (Photoshop) as I've done in the past. The icon is grayed out. I have a feeling this is one of those "duh" questions but I could use some help.
                          Thanks in advance.
                          • iMac late 2013
                          • OS 10.8/5
                          • Processor: 3.5 GHz Intel COre i7
                          • Memory: 32 GB 1600 MHz DDR3
                          • Vray 2.0 and SU 2013
                            Under SketchUp > Preferences have you set the path to your image editing package?
                              driven
                              you can only edit 'in Model' materials, not ones in libraries...
                              paint something first, go to 'In Model' then select to edit...
                              john
                                good spot!
