    GRID DISTORTION
    42 Posts 8 Posters 1.7k Views 8 Watching
    • jeff hammondJ Offline
      jeff hammond
      @gilles said:
      Vasarely died 1997 march 15, not really these days. Hihi 😄
      right.. but there are innovators then followers .. but i think he's more/less the grandfather of the movement.
      the top (more recent) picture is a computer model which then went to cnc to be laser cut.. all them brooklyn kids with rhino and cnc machines have this stuff going on 😉
      also the software processing:
      http://processing.org
      i've seen people doing this kind of stuff in flash too..
      dotdotdot
        jeff hammond
        [edit] the guy who made this video (and the plywood grid i posted earlier) ..
        Marius Watz
        Explore Marius Watz’s 7,533 photos on Flickr!
        Flickr (www.flickr.com)
        go get lost in that photostream for a few hours.. good stuff..
        dotdotdot
          @gilles said:
          ...Vasarely died 1997 march 15, not really these days. Hihi 😄
          Ah well, here is a great cult of him as he was born in my town (as Győző Vásárhelyi - "Győző" literally means "Victor" and the last name "Vasarely" is just a bastardization of his original surname as "vásárhely" means "marketplace") and he has a quite big exhibition here.
          • I Offline
            infinity
            Here is a picture of what I would like to do as well as the piece of art work.
            So do you think that thomthoms vertex tool plugin will achieve this.
            I was thinking that I could export it as a 2D dxf file to my CAM software.
              jeff hammond
              weird.. i can't really figure out if that thing is perspective dependent or not.. but i'm leaning towards it is..
              (as in, you have to stand at the same vantage point as the photo was shot from in order to get the full effect)
              if that's the case, i don't really know what you should do.. besides experiment..
              do a few smaller scale tests comprising of forming a grid then moving vertices around manually using the move tool (with nothing selected, click the move tool on one of the grid intersections and move it around)..
              figure out what needs to happen first.. then you'll be able to figure out if vertex tools is the right tool..
              (or hey.. generally a helpful bunch around here.. maybe someone will figure it out for you 😉 )
              personally, i'm about to switch back to work mode so i don't have the time/energy right now...
              dotdotdot
              • I Offline
                infinity
                Thanks Jeff, I really appreciate your input on this
                • gillesG Offline
                  gilles
                  SketchyFFD:
                  http://sketchucation.com/forums/viewtopic.php?p=36127#p36127
                  • gillesG Offline
                    gilles
                    For some reason only the first version works for me?
                    • I Offline
                      infinity
                      How did you create this gilles?
                      I have the sandbox tools and can do the same as you did with the black and white squares one but I dont know how to get a top view to show all the distorted lines.
                      • gillesG Offline
                        gilles
                        A little video
                        http://www.screencast.com/t/yt9gej2g
                        Also read this if you want to try this plugin:
                        http://sketchucation.com/forums/viewtopic.php?f=323&t=6029&start=300#p454588
                        • I Offline
                          infinity
                          Thanks for the video.
                          I have downloaded the plugin and pasted it into the plugins folder but it does not appear. Is there something else I should be doing?
                          • massimoM Offline
                            massimo Moderator
                            It appears in context menu: right click on a group-->FFD...
                            • gillesG Offline
                              gilles
                              The plugin won't appear in plugin window.
                              Right-click on a group and find FFD in the context menu.
                              Carefully read the original thread, it is not a so easy plugin as you don't see deformation in real time.
                              So, save before use and practice a lot.
                              It may be easier to draw this thing by hand with Fredo6 bezier tools if you want to reproduce the exact thing your picture shows.
                              Up to you to choose. Good luck and fun
                                jeff hammond
                                i'm kinda thinking there are two different things going on in the thread.. the tree example is different than the examples i posted..
                                meaning, the grid work ala vasarely is meant to be viewed as a 2D piece more or less from straight on..
                                the tree is more of an optical illusion thing though.. (and maybe it's arguable that the paintings are also optical illusions but the tree thing is more gag like.. the punchline or hook or whatever is being shown to you precisely so youre not left wondering or interpreting the piece yourself.. it's main purpose is to leave the viewer visually disoriented in a realm not so different than that of a magician.. you know?)
                                anyway... it seems as if the way to do the tree drawing is sort of a combination of what gilles and dave both showed earlier..
                                draw the thing in 3D.. something like the sanbox method which was shown.. then align a plane in such a way that when the object is draped, it will look like the 3D version except it's flat.. something like what dave was showing..
                                set up a scene so you can continue to return to the same perspective..
                                something like that
                                dotdotdot
                                • I Offline
                                  infinity
                                  OK Jeff I have made one using the sandbox tools and I have tried draping it on to another plane. This is where I am coming unstuck. I don't seem to be able to align a plane that it will appear to be 3D when its looked from above.
                                  Any chance of an example please if you have the time?
                                    Think about the physics of what you want to accomplish. The illusion will really only work from one vantage point. Figure out where you want that to be and determine the angle between your 3D mesh and the viewer. Use that angle, or actually its compliment, as the angle between the mesh and the plane onto which you'll project the image.
                                      I recall writing a short script to 'project' objects' outlines onto the floor-plane for this kind of thing ? ........ http://sketchucation.com/forums/viewtopic.php?p=320466#p320466
                                      • I Offline
                                        infinity
                                        Wow TIG thats a really good plugin.
                                        I have now produced a distorted grid and have exported it as a dxf into my CAM software.
                                        There are a lot of open vectors which I can join most of them by using the 'join' tool in the CAM software. There are still open vectors and when I further try to join these, the lines become broken.
                                        Is there a way that I might be able to export this file so my CNC router will be able to cut single lines in the grid both vertically and horizontally?
                                          Some screen-shots, and an example SKP file [perhaps simplified?] might help..
                                          • I Offline
                                            infinity
                                            Here is the sketchup file that I exported as a dxf
                                            grid distortion
                                            • 2 / 3
