    Joining round to square
    39 Posts 10 Posters 2.4k Views 10 Watching
    • hellnbakH Offline
      hellnbak
      What's the best (and easiest) low poly way to blend a round shape to a square shape, like in the attached photo? I know this is probably a silly question to ask, but my brain is tired and I need to get this done.
        You could use Curviloft to join the round to the square with some shallow arcs drawn between.
          You say "more easy" so curviloft πŸ’š
          Ah damned I lost the time to make the image! πŸ˜†
            You can also
            draw a circle
            Draw a polygon 4 sides from the center of circle bigger than the circle
            Then Move the circle with Up ARROW Pressed πŸ˜‰
              Those won't result in the curved transition between square and round. πŸ˜‰
              • hellnbakH Offline
                hellnbak
                Crap, looks like I'm finally gonna have to learn Curviloft. I've been avoiding that. πŸ˜’
                  No problem from this point of view! πŸ˜†
                    Nice, Pilou. πŸ˜„
                    HnB, it's not that much to learn at least for this.
                    Draw the shape as shown selected, click the indicated button, hit Enter. Done.
                    • hellnbakH Offline
                      hellnbak
                      Dang, that looks too easy! (gotta have something to complain about)
                      Thanks much
                        Well complain about the weather, then. It's too damn cold and there's nothing anyone can do about it. πŸ˜„
                        • hellnbakH Offline
                          hellnbak
                          Sure there is
                            At least there are no man-eating snakes here. πŸ˜„
                              Well, today it was so "hot" (okay warm) here that I ws already expecting the almond trees to start blossoming. I was out in a single T-shirt and a thin jacket but sweating like a horse after shopping.
                              • hellnbakH Offline
                                hellnbak
                                hope you got sunburned
                                • hellnbakH Offline
                                  hellnbak
                                  we're expecting up to two feet of the white crap today and tomorrow
                                    Well, we don't have that much and you can still see the grass in some places under the ice we got on Sunday but It's like 2 degrees F with a windchill of -28 or something. Supposed to be -15 or something tonight with even lower windchill.
                                    • jeff hammondJ Offline
                                      jeff hammond
                                      maybe more difficult to learn at first in curviloft but a faster method once you figure it out is to use the loft option in curviloft..
                                      you wouldn't need profile splines to do it this way..
                                      select the square and the circle
                                      choose loft (first icon in curviloft)
                                      choose one of the bezier options for 'spline method'
                                      click on the black preview loft which will open a separate options panel
                                      adjust tension accordingly (increase segments as well for a smoother transition if needed)
                                      doing it like that also allows you to rapidly explore different blends via the tension controls as opposed to being stuck with the manually drawn profiles then needing to start over if you don't like it..
                                      dotdotdot
                                      • gillesG Offline
                                        gilles
                                        I would have made this.
                                          jeff hammond
                                          oh.. right.. that's how it really looks anyway.. especially if it were lathed..
                                          πŸ‘
                                          dotdotdot
                                          • gillesG Offline
                                            gilles
                                            πŸ’š I think they were.
                                            • 1 / 2
