    Joining round to square
    39 Posts 10 Posters 2.3k Views 10 Watching
      You can also
      draw a circle
      Draw a polygon 4 sides from the center of circle bigger than the circle
      Then Move the circle with Up ARROW Pressed πŸ˜‰
        Those won't result in the curved transition between square and round. πŸ˜‰
        • hellnbakH Offline
          hellnbak
          Crap, looks like I'm finally gonna have to learn Curviloft. I've been avoiding that. πŸ˜’
            No problem from this point of view! πŸ˜†
              Nice, Pilou. πŸ˜„
              HnB, it's not that much to learn at least for this.
              Draw the shape as shown selected, click the indicated button, hit Enter. Done.
              • hellnbakH Offline
                hellnbak
                Dang, that looks too easy! (gotta have something to complain about)
                Thanks much
                  Well complain about the weather, then. It's too damn cold and there's nothing anyone can do about it. πŸ˜„
                  • hellnbakH Offline
                    hellnbak
                    Sure there is
                      At least there are no man-eating snakes here. πŸ˜„
                        Well, today it was so "hot" (okay warm) here that I ws already expecting the almond trees to start blossoming. I was out in a single T-shirt and a thin jacket but sweating like a horse after shopping.
                        • hellnbakH Offline
                          hellnbak
                          hope you got sunburned
                          • hellnbakH Offline
                            hellnbak
                            we're expecting up to two feet of the white crap today and tomorrow
                              Well, we don't have that much and you can still see the grass in some places under the ice we got on Sunday but It's like 2 degrees F with a windchill of -28 or something. Supposed to be -15 or something tonight with even lower windchill.
                              • jeff hammondJ Offline
                                maybe more difficult to learn at first in curviloft but a faster method once you figure it out is to use the loft option in curviloft..
                                you wouldn't need profile splines to do it this way..
                                select the square and the circle
                                choose loft (first icon in curviloft)
                                choose one of the bezier options for 'spline method'
                                click on the black preview loft which will open a separate options panel
                                adjust tension accordingly (increase segments as well for a smoother transition if needed)
                                doing it like that also allows you to rapidly explore different blends via the tension controls as opposed to being stuck with the manually drawn profiles then needing to start over if you don't like it..
                                • gillesG Offline
                                  gilles
                                  I would have made this.
                                    oh.. right.. that's how it really looks anyway.. especially if it were lathed..
                                    πŸ‘
                                    • gillesG Offline
                                      gilles
                                      πŸ’š I think they were.
                                        That is indeed more correct, Gilles.
                                        Lathed? Turned on a lathe. In woodworking, anyway, "lathe" is a noun. πŸ˜‰
                                          yeah.. i think lathed would mean 'applied laths' maybe? in which case, the wheelbarrow handles were more likely than not-- not lathed!
                                          πŸ˜‰
                                          edit- funny thing though.. i typed 'turned' then deleted it because i thought that might be confusing to some..
                                          turns out, my replacement is wrong πŸ˜†
                                            Maybe with this πŸ˜„
                                            http://coloriage.mobi/images/taille_crayon.gif
