    What's wrong with these polygons?
    15 Posts 5 Posters 825 Views 5 Watching
    • alejandeA Offline
      alejande
      Dear all, I need your help. Why some polygons/edges in this model look like this?
      C2Q 8200@3GHz:6Gb Ram:GTX 650 Ti
        It's hard to tell without seeing the SKP file but it looks to me as if either those edges are hidden instead of softened and/or there are internal faces connected to those edges.
        • Chris FullmerC Offline
          I think Dave's got some good intuition on that - πŸ‘ . Could you upload the model?
          All my Plugins I've written
          • alejandeA Offline
            alejande
            Here is closeup view of the top-right poly.
            I manually deleted all 3 lines, then made them again with "Line" tool, and erased with Ctrl pressed. Nothing changed. This put me into a dead end. πŸ˜•
            • jeff hammondJ Offline
              jeff hammond
              my guess.. nothing is wrong with them.. ?
              (edit) i mean- why are you saying something is wrong? the shading?
              [edit2] well, actually.. along with what dave is saying, are you sure you know the difference between hidden lines and softened lines? the dashes are hard to see in the screenshots but they're looking hidden.. but that's shift-eraser)
              dotdotdot
              • alejandeA Offline
                alejande
                Allright, here it is:
                zil_debug.zip
                • gillesG Offline
                  gilles
                  its just something to see with shadows, if you change a little the hour or the month everything goes ok.
                    jeff hammond
                    yeah.. thats the way the flat surfaces are shading (you can't have a truly gradual shade on a curved object being represented by flat facets.. not inside of sketchup itself..)
                    here's your model with the sun position changed.. now you have 'problem' polygons in other locations.. see?
                    zil_debug.skp
                    [edit- yeah.. what gilles is saying]
                    dotdotdot
                    • alejandeA Offline
                      alejande
                      Do you think so? They look very hard-edged on a render. I don't like it at all ))
                      • alejandeA Offline
                        alejande
                        [attachment=0:1f7woi5z]<!-- ia0 -->zil_debug.skp<!-- ia0 -->[/attachment:1f7woi5z]
                        Now i understand. I made a render with another sun position and yes, hard edges appeared in the some new positions. And how it can be avoided? I need to make more hi-poly model?
                        • gillesG Offline
                          gilles
                          I am not very aware with render, but you must have option in them to soft edges without increasing geometry.
                            What software are you using to render with?
                            • alejandeA Offline
                              alejande
                              V-Ray 1.49.02
                                In SketchUp you'll see that those faces that are extra dark are in a shadow from the sun. Try this, turn off shadows and turn on "Use Sun for Shading". You see you get a smooth shading, but no hard shadow lines. I know that doesn't help with V-Ray though.
                                Maybe in v-ray do something to help diffuse your sunlight. I'm not sure how V-Ray works, but can you make you sun physically larger? I think it would help if you didn't have a small point of light casting the shadows, but if you had instead a large light that would create softer shadows. That might be something to try.
                                • alejandeA Offline
                                  alejande
                                  Thank you very much for bringing me to a couple of ideas! πŸ‘
                                  1.Increase the size of the sun (1 to 24):
                                  1. Do not use the sunlight at all. I tried a rectalgular light instead:
                                  I think I shall not use sunlight with this model.
                                  And thanks to all for suggestions!
