    Barley Twist Spirals
    119 Posts 12 Posters 14.8k Views 12 Watching
      archturn
      I'm looking for a way to model my stair newels in Sketchup. The attached barley twisted newel was made in my CAD program but I am hoping for a method to do the same in Sketchup. Would appreciate any help.
      • jeff hammondJ Offline
        jeff hammond
        do you mind giving a little background first? what's your current sketchup level? are you ok with using plugins or would you prefer to do it using native sketchup tools?
        dotdotdot
          archturn
          I'm probably an intermediate user. I'm fine with using plugins. I've looked in vain though to find one that will help
            This shows how I do them. And a couple of examples.
            http://farm4.staticflickr.com/3400/4632041011_06f915b614.jpg
            http://farm5.staticflickr.com/4020/4653175758_1c8f0707f8.jpg
            • pbacotP Offline
              screw.rb can make this pretty well and fast. But I bet the geometry created by Dave's method would be nicer.
              • gillesG Offline
                gilles
                There is no reason, it depends of how many steps you type in the prompt window.
                • gillesG Offline
                  gilles
                  Made in one shot with screw1_5.rb.
                  AND it works also with components.
                    Gilles, yours shows a nice spiral or screw but that's not a barley twist. The barley twist consists of multiple starts. It is possible to make the barley twist with Screw, though.
                    This is a three-start barley twist.
                      the new classic πŸ˜‰
                      • gillesG Offline
                        gilles
                        Sorry Dave, there are two starts and I could have done n starts in one shot.
                        OFF TOPIC
                        components plus profiles in one shot:
                          Pilou, you trot that video out every time someone asks how to draw anything. πŸ˜’ πŸ˜†
                          That's not a barley twist either.
                            Show the setup. And which version of Screw are you using.
                            • gillesG Offline
                              gilles
                              screw1_5.rb.
                              select 3 profiles (in the following case), set start point, set end point, enter n steps n turn and go.
                                Thanks. that should help the OP.
                                Isn't it great there are usually multiple ways to arrive at the same point in SketchUp?
                                And you finally drew a barley twist. πŸ˜‰ Here's a cutter profile for that.
                                http://ecx.images-amazon.com/images/I/31uqkUSlwNL.jpg
                                  True but otherwise a brilliant solution!
                                  (I could imagine Kito Raupp is Pilou himself in a humble disguise)
                                  πŸ˜†
                                  • gillesG Offline
                                    gilles
                                    Here is a step by step.
                                    profile
                                    follow me around the circle
                                    erase unwanted
                                    intersect
                                    erase unwanted
                                    select the two profiles (center must be on blue axis at origin) run screw plugin
                                    cut  unwanted whit zorro plugin
                                    intersect
                                    erase unwanted
                                      archturn
                                      This is what we call a rope twist not a barley twist. The barley twist has another (interior) radius. The rope twist looks like rope - though your method may work for a barley twist as well. David R's is definitely a barley
                                        Nice rope twist. πŸ˜‰
                                          archturn
                                          Love your solution but I need to fit it to the other part of my newel. Gilles method looks like it will work. In CAD I'll usually do a sweep of the newel profile then draw my barley twist profile - sweep the barley profile with the correct pitch then subtract it from my newel sweep. I wish I could do it this way (specifically the subtract function) in SU since this yields the most realistic geometry - though again Gilles looks pretty right (just needs more interior radius to be classified as a true barley twist). Thanks
                                          • gillesG Offline
                                            gilles
                                            Its up to you to create the good profile. πŸ’š
                                            You can also do this with screw:
                                            • 6
                                            • 1 / 6
