    Barley Twist Spirals
    119 Posts 12 Posters 9.5k Views 12 Watching
      archturn
      @gilles said:
      Here is your model with some corrections and the use of components,note it is 650Kb instead of 1950.
      Looks better than mine. So you redid the spiral?
        found a situation where a group made more sense than a component.
        You have some plugins who works only with groups! πŸ˜‰
        You're right. And when I use them I wind up converting the groups to components. I'd be happier if a component was just created by the plugin.
        I haven't found a need to use any plugins that only work on groups.
          archturn
          @dave r said:
          Gilles version of your model illustrates very clearly the reduction in file size that I mentioned earlier. πŸ˜‰
          And even 100 of them is only 820 Kb. That's a couple of hours of production in your shop, right?
          Wish I could make them that fast. I missing something - would like to know your work flow on the spiral
            I'd be happy to show you. I can't do it at the moment, though. Maybe another live demo with you or I'll make a video.
                archturn
                Dave
                That'd be great!!
                  and here for example after explode the original component for paint each faces
                  I don't need to make a component again, but just a group! πŸ˜‰
                    @archturn said:
                    Dave
                    That'd be great!!
                    Maybe a live demo this weekend?
                      archturn
                      @dave r said:
                      @archturn said:
                      Dave
                      That'd be great!!
                      Sounds good
                      • daleD Offline
                        dale
                        I just want to thank you all for this thread. It has been a great learning experience. πŸ‘
                        • gillesG Offline
                          gilles
                          No I did not, its your model where I cut part of geometries to make components πŸ˜„
                          • pbacotP Offline
                            This thread is hot! Another point I would make is with screw.rb one can then make a component of spiral section that would stack directly beneath the other (without turning) and so you could increase, vary the height (within a module) easily.
                            I assume that can be done with Gilles' version.
                            • gillesG Offline
                              gilles
                              Yes we can!
                              huhu couldn't resist.
                                archturn
                                If I understand you right this is one method I used - I made a 2 1/2" profile (the profile of my barley twist router cutter) then used the screw plugin to make a 5" high one revolution spiral. I grouped it, then copied and stacked it on top the other spiral. I then selected those to array the rest of the way.
                                  That's pretty much it but use a component instead of a group.
                                    archturn
                                    Still not sure why there is such a difference in file size
                                      I believe it's quasi the same size maybe a little less for the group because there is less informations inside no Glue etc..., but same info as pure geometry.
                                      • gillesG Offline
                                        gilles
                                        Isn't it a big difference?
                                        Also modifying all instances at once.
                                        Create libraries for further use in other models.
                                          archturn
                                          Re: file size of my barley twist stair newel
                                          I'm still perplexed by the size of my file. I started over with a new SU file and made my newel without the barley twist. After imported my profile from CAD, did a sweep, created a component of the newel and my file size is 3 MB. What gives?
                                          BTW I have purged layers from the CAD file import
                                            How many segments did your imported profile turn out to have? The profile I created last night with the Bezier tool had 22 (including the two little short segments I added at the ends. And the total number of entities after one turn of the screw was 2686.
                                            • 6
                                            • 5 / 6
