    Scaling native .vismat material
    renderpluginsextensions
    14 Posts 6 Posters 2.2k Views 6 Watching
    • jonedvardJ Offline
      jonedvard
      i imported a native 'sea water' material and would like to increase the texture. i would like to exaggerate the current default map - where the 'ripples/bump' will appear larger in scale.
      cheers -
      jon
      • andybotA Offline
        andybot
        can you show the "M" (material texture) dialogue that is next to the displacement option? The UVW information will be shown there. Note that units are in inches.
          jonedvard
          here:
          • P Offline
            pierreaudouin
            you can change u/v "repeat"
            • panixiaP Offline
              panixia
              try changhing both u repeat and v repeat and set both of them to 0,1 (if it's still not big enough try 0,01 and so on..)
              • ATLAStudioA Offline
                ATLAStudio
                For noise maps I tend to adjust the size. Here's an example with a perlin noise bump map for speed. On a side note, apparently vray spheres don't really like accepting shadows, and have horrible edges.....maybe I'm using them in the wrong way.
                Noise size 0.5
                Noise size 10
                Noise size 50
                http://www.atlas-studio.co.uk
                  rspierenburg
                  Hey that looks really good. Where do you set the Perlin noise size exactly? Is it the same as UV repeat?
                    ATLAStudio
                    If you look at jonedvard's last attachment showing the texnoise window you'll see a dropdown under the colour A/B for type, you can change to different noise types in there. The size setting is to the right of that.
                      jonedvard
                      wow! that's exactly the intended look that i was trying to sort.
                      thanks to all!
                        jonedvard
                        alright. some minor clarification.
                        panixia - i'm trying to understand 0,01 values. is that referring to (0 for both u/v repeat) and (0.1 for both u/v offset)?
                        also, the example you provided is a decreased value. am i actually needing to decrease my values in order to create a larger texture/pattern?
                        ATLAStudio - concerning perlin texnoise maps. should i adjust it to match the u/v repeat sizes? or does that not matter?
                        sorry for my confusion! 😄
                          jonedvard
                          oh and regarding the spheres. my approach would be to increase the number of segments when creating your sphere - providing a smoother surface. an arc with about 48 segments is what i generally use for a fairly adequate smooth surface. hope that helps!
                            ATLAStudio
                            The way I did it doesn't involve any adjustment of UV, just leave them all at 1.0.
                            • panixiaP Offline
                              panixia
                              i was ferring to u/v repeat, but actually i was wrong, because text noise acts in a different way than the most other maps.. for example rock, stucco etc.. with those changing the uv repeat would work (once you untick enable "3d mapping")
                              • andybotA Offline
                                andybot
                                It's called the "terminator" problem
                                @ATLAStudio - good info, thanks! For me, I just keep re-loading a working water vismat, so I didn't remember off-hand which setting it was...
