    Layer Visibility for Multiple Scenes
    5 Posts 4 Posters 939 Views 4 Watching
    • svzephyrS
      svzephyr
      Is there a plugin to quickly set a layer's visibility in all the scenes in a model?
      I typically create a model with many scenes. But, if I add a layer that might only need to be visible on 1 or 2 scenes it's tedious to go through each scene, set the layer visibility, then update the scene.
      I haven't used layers very much; I normally just use the scenes and the plugin HideInOtherScenes to control visibility. This works fine for groups and components, since I can use the Outliner to temporarily unhide items, but finding text, dimensions, etc. can be challenging.
      • TIGT
        This one-liner copy+pasted into the Ruby Console + <enter> will make the named layer visible in all scenes... Edit the n="xxx" to suit the layer's name you wish to make visible...
        n="MyLayerName";m=Sketchup.active_model;la=m.layers[n];m.pages.each{|p|p.set_visibility(la,true)}
        Changing the vivibility option from 'true' to 'false' makes that named layer 'NOT visible' in all scenes, thus:
        n="MyOtherLayerName";m=Sketchup.active_model;la=m.layers[n];m.pages.each{|p|p.set_visibility(la,false)}
        • C
          caronte01
          Try this plugin:
          Error 404 (Not Found)!!1
          (sketchuptips.blogspot.com)
          or this one, seems to be an evolution on the first plugin
          http://sketchucation.com/forums/viewtopic.php?f=10&t=36583&p=322249&hilit=+add+hidden+layer+#p322249
          • svzephyrS
            svzephyr
            Thanks, all - I've tested Add_Scene_Layer.rb and I think it will do the trick for me nicely. Maybe I'll even get to liking layers πŸ˜„
            • thomthomT
              http://www.srww.com/blog/?p=1205
              Layers Management Ruby Script For SketchUp
              http://www.srww.com/blog/wp-content/uploads/2010/05/layerstoolbar.png
