    Biagio lamp
    14 Posts 8 Posters 728 Views 8 Watching
    • massimoM Offline
      massimo Moderator
      A sexy shape. Was designed in 1968 by Tobia Scarpa (the son of Carlo). Lamp body carved from a single block of Carrara marble.
      Modeled with SU and rendered with Thea. Relight and CRF in Thea and just a slight noise reduction on the lamp + contrast, color correction, diffusion and vignette in Magic Bullet Photolooks. πŸ˜„
      • CarlohC Offline
        Carloh
        impressive! πŸ‘ reminds me of the nautilus speakers from bowers & wilkins...
        http://audiovisualinfo.com/wp-content/uploads/2012/10/BW-Nautilus-Main.jpg
        • P Offline
          pier70
          Hi massimo, very nice, which plug in have u used? curviloft...thank u
            Macker
            I think the design of the lamp is particularly ugly (personal taste), however the material setup and modelling is quite excellent. Well done.
            Check out my blog @ http://macviz.blogspot.co.uk
            • P Offline
              pier70
              the last image that u posted, is an image from su or a render?it seems from su...
              • massimoM Offline
                massimo Moderator
                Thanks guys. πŸ˜„
                Reminds me of the nautilus speakers from bowers & wilkins...
                Yeah, just a bit. πŸ˜‰
                No plugins were used for most modeling. Actually despite the appearance it's quite a simple shape. See the picture below.
                The worst part was beveling the edges since nothing quick worked. So I've used the "offset" tool from Fredo's "tools on surface", then erased the corners and rebuilt the surfaces.
                Really? I find it quite fascinating (personal taste of course). πŸ˜‰
                Yeah, it's raw SU.
                • Bryan KB Offline
                  VERY nice. πŸ‘
                  • massimoM Offline
                    massimo Moderator
                    Thank you Bryan. πŸ˜„
                      That is tasty.
                      I'd love to see the material settings.
                      • massimoM Offline
                        massimo Moderator
                        Here you go Rich. The texture is always the same of the diffuse slot. πŸ˜„
                        Based on Patrick's 3d print material.
                        • alvisA Offline
                          alvis
                          Grand Master 😲
                          • massimoM Offline
                            massimo Moderator
                            Thank you very much Alvis. πŸ˜„
                            • novenaN Offline
                              novena
                              I just can articulate: R E S P E C T !
                              http://hdzarkitektur.wordpress.com/
                              • massimoM Offline
                                massimo Moderator
                                Thanks Victor. πŸ˜„
