    Applying colour not able to do
    9 Posts 4 Posters 537 Views 4 Watching
    • E Offline
      Earle
      From time to time I find myself not able to apply colour or textures, no matter if I triple click on component or just to closed component I can't apply colour- It must be a simple proceedure I am missing-any suggestions?
      Earle
        Very likely it is just the face style you are using. Go to View>Face Style and make sure you have either Shaded or shaded with texture selected before you start applying materials and colors.
        It's a good idea to work in Monochrome style when you are drawing so you can easily keep tabs on reversed faces and correct them as they occur.
          mrossk
          make sure that the correct face style is selected. If you're in "monochrome" stlye, materials won't appear even if they are technically applied to the surface.Capture.JPG
          https://www.mkaplanfinefurniture.com/
            mrossk
            jinx!
            • Rich O BrienR Online
              Is your face style set to monochrome?
              If so try setting it to shaded with textures.
                As with a lot of things in SketchUp, there's usually more than one way to get to the final result. πŸ˜†
                • E Offline
                  Earle
                  Shaded with texture is selected.
                  • E Offline
                    Earle
                    Thanks-don't know what I was doing but it works now?
                      And that fixed the problem?
