    Slicing complex models
    15 Posts 5 Posters 870 Views 5 Watching
    • T
      tspco
      Today I made a nice column, but now I need half a column, that looks the same. I tried Zorro, but it can't cut straight, even in "front" or "top" view. I tried Section Cut Face, and managed to get the job done, after a few tries. Is there a better way to make half a column?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • Chris FullmerC
        Can you just intersect the column with a plane and then right click on the plane and choose intersect -> Intersect with Model?
        That will then cut through the column and you just erase out the half you don't want.
        All my Plugins I've written
        • T
          tspco
          I tried that but failed, but I tried again and had success. Guess I didn't think it would be that simple;)
            One thing you might consider for future columns is to make only half or less of the column to begin with, make it a component and then copy it to make the rest of it when you need a full column.
            In this example I made an eighth of the post (as on the right) and then placed copies to complete the full column. I can make a 3/4, 1/2 or 1/4 column easily from it.
            • pbacotP
              Be sure to try "hidden geometry on" with such shapes and it may help show what is going on and where it needs to be cut etc.
              • T
                tspco
                I tried that Dave, I started with a square box and used the follow me tool, great, turned out just like I wanted, so I made a half wide rectangle, did the same thing with the follow me tool, only one face of the of the three, had the profile. I tried a couple of times, same result. That's when I started, looking in to cutting the full version in half. Also thanks to pbacot for the suggestion.
                  I'd like to see what you were trying to accomplish. I'll bet it can done.
                  • T
                    tspco
                    I just tried it again, and realized what I did, one of those duh moments, I had my profile outline in the wrong place.
                      That's what I was wondering. πŸ˜‰
                      • T
                        tspco
                        Now then how would I make a column with a sloped top?
                          Does this help? Or are you wanting only, say, a quarter of the column?
                          • TIGT
                            Dave beat me to the draw...
                            FollowMe on the profile around a square.
                            OR
                            Select the parts you want bigger on a premade column and use Scale + Ctrl to centralize the scaling-anchor and enlarge the top parts that way.
                            OR
                            ... there are many ways, it depends what you you are starting with...
                            • T
                              tspco
                              As far as the sloping top goes, in the picture I posted, it looks like they just shaved the top to fit the slope. I don't have a bigger picture to look at.
                                I didn't catch that the ceiling has a slope to it. I would draw the column as TIG or I have shown and then cut the top with a cutting plane and Intersect Faces.
                                • T
                                  tspco
                                  That's what I did, then I made half columns, and corner columns. Actually doesn't look to bad.
