    Slicing complex models
    15 Posts 5 Posters 839 Views 5 Watching
    • pbacotP Offline
      Be sure to try "hidden geometry on" with such shapes and it may help show what is going on and where it needs to be cut etc.
        tspco
        I tried that Dave, I started with a square box and used the follow me tool, great, turned out just like I wanted, so I made a half wide rectangle, did the same thing with the follow me tool, only one face of the of the three, had the profile. I tried a couple of times, same result. That's when I started, looking in to cutting the full version in half. Also thanks to pbacot for the suggestion.
        SU make 2017, /Twilight Render Hobby
        Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
          I'd like to see what you were trying to accomplish. I'll bet it can done.
            tspco
            I just tried it again, and realized what I did, one of those duh moments, I had my profile outline in the wrong place.
              That's what I was wondering. πŸ˜‰
                tspco
                Now then how would I make a column with a sloped top?
                  Does this help? Or are you wanting only, say, a quarter of the column?
                    Dave beat me to the draw...
                    FollowMe on the profile around a square.
                    OR
                    Select the parts you want bigger on a premade column and use Scale + Ctrl to centralize the scaling-anchor and enlarge the top parts that way.
                    OR
                    ... there are many ways, it depends what you you are starting with...
                      tspco
                      As far as the sloping top goes, in the picture I posted, it looks like they just shaved the top to fit the slope. I don't have a bigger picture to look at.
                        I didn't catch that the ceiling has a slope to it. I would draw the column as TIG or I have shown and then cut the top with a cutting plane and Intersect Faces.
                          tspco
                          That's what I did, then I made half columns, and corner columns. Actually doesn't look to bad.
