    Launch animation
    17 Posts 3 Posters 1.1k Views 3 Watching
    • inteloideI Offline
      inteloide
      Hello
      Can anyone tell me, in ruby, how to launch animation (like using sketchup standard function) to show each pages of the model ?
      The idea is to make a toolbar that allow you to play, pause and stop the animation.
      Thanks for your help.
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        Read the API - you need to combine various methods into a new toolset.
        Note that 'scenes' are referred to as 'pages' in the API...
        https://developers.google.com/sketchup/docs/ourdoc/pages
        https://developers.google.com/sketchup/docs/ourdoc/animation
        https://developers.google.com/sketchup/docs/ourdoc/sketchup#send_action [page... actions]
        etc etc...
          inteloide
          Hello TIG,
          Thanks for your answer, mainly for the last link, which I didn't read yet.
          But the issue I have is to keep the animation running.
          With my code below, I made a class which show scenes page by page
          But the animation stop when I change the page (pages.selected_page = model.pages[$xg])
          Also I don't know if switch time between pages will be as per value defined in sketchup parameters...
          Any idea, or other way to proceed ?
          class Anima
          def initialize
          $xg = 0
          def nextFrame(view)
          pages = Sketchup.active_model.pages
          model = Sketchup.active_model
          #UI.messagebox $xg
          $xg+=1
          if $xg > pages.count then
          $xg = 0
          #view=Sketchup.active_model.active_view
          #view.show_frame
          return true
          def stop
          UI.messagebox "fin"
          end #class
            A few points...
            Use @xg which is specific to that instance of your class... and NEVER use $xg which would be global to ALL scripts loaded...
            To keep it going reset @xg=0 if @xg>pages.length-1 - so it never ends... remember that an array starts at 0 so you need the -1 when doing a comparison .....
            • renderizaR Offline
              renderiza
              This proposed feature by inteloide should be integrated by default in the next Sketchup version. Having to click three times to play the animation is no good so I'll be keeping an eye when this plugin is done ๐Ÿ˜„
              [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                inteloide
                ok, by changing to :
                @xg=0 if @xg>pages.size-1
                all pages are activated, but without any break between each of them. (it's like it goes directly to the last page). How to implement a break ?
                Also it doesn't loop : when the last page is shown, it stops (doesn't loop). Any reason why ?
                Thanks again.
                I will post my complete plugin when finish. Actually it's based on mover.rb plugin (to move components between pages) but I wanted to add a toolbar to have all tool within on click.
                  Read the Page section of the API.
                  page.delay_time gives the time to delay between pages [there is also transition_time], you could try using it/them between page changes, using a UI.start_timer(...){...} for each page ? [untested]...
                  If it's -1 you need to also get the model's page-options to find what the default value is...
                  Sketchup.active_model.options["SlideshowOptions"]["SlideTime"]
                  Sketchup.active_model.options["PageOptions"]["TransitionTime"]
                  etc
                    inteloide
                    Thanks TIG for telling me to look at Page API, because I thought it was only a collection (Pages) and not an entity.
                    So at the end, the solution I found is the following one :
                    def lire_anim (p) model = Sketchup.active_model pages = model.pages pages.selected_page = pages[p] if p<pages.size-1 then id = UI.start_timer(Sketchup.active_model.options["PageOptions"]["TransitionTime"], false) { lire_anim(p+1) } end end
                    and to launch : lire_anim(0)
                    Now, I need to find a way to stop animation while it's running...
                      You also need to understand view.animation= etc...
                      https://developers.google.com/sketchup/docs/ourdoc/view#animation=
                      Add this into your script's methods
                      animation = Anima.new()
                       view = model.active_view
                       anim = view.animation=animation
                       if (anim)
                         UI.messagebox anim
                       else
                         UI.messagebox "Failure"
                      To cancel the current view's animation use view.animation=nil
                        inteloide
                        I'm close to the aim !
                        I have 2 issues :
                        1-When start the animation it goes to "stop" subrouting but it doesn't stop animation ...?!
                        2-When setting view.animation to nil, it' doesn't stop... ?!
                        Again your help is welcome !
                        class Class_Run_Animation def initialize puts "Start of animation" show_scene(0) end def show_scene(p) puts "Go to scene #{p}" pages = Sketchup.active_model.pages pages.selected_page = pages[p] if p<pages.size-1 then id = UI.start_timer(Sketchup.active_model.options["PageOptions"]["TransitionTime"], false) { show_scene(p+1) } return true else puts "End of loop" return false end end def stop puts "Loop stopped" return false end end
                          You loop through the pages and then return false, this stops it, you never call stop, and don't really need to...
                          You should only use the initialize() method to set up @ variables etc, if needed...
                          You have dropped the def nextFrame(view)... Why? I think this is confusing the issue... Using it would let you create an animation class object that you could assign to the view [looping through the scenes [pages] etc] in some separate code with view.animation=Class_Run_Animation.new(), then you can later cancel with view.animation=nil.
                          The separate code used would be something like:
                          module Inteloide
                            def self.start_animation()
                              Sketchup.active_model.active_view.animation=Class_Run_Animation.new()
                            def self.end_animation()
                              Sketchup.active_model.active_view.animation=nil
                          Used in the console [or added to a toolbar command] as
                          Inteloide.start_animation
                          and
                          Inteloide.stop_animation
                          Your earlier code could be readily adapted to do this...
                            inteloide
                            ok, I changed to an animation class, but it still don't stop
                            I think the issue comes from the start_timer which start the procedure even if animation is stopped.
                            ` class Class_Run_Animation
                            def initialize
                            #show_scene(0)
                            @p=0
                            def nextFrame(view)
                            puts "Go to scene #{@p}"
                            pages.selected_page = pages[@p]
                            if @p<pages.size-1 then
                            @p+=1
                            id = UI.start_timer(Sketchup.active_model.options["PageOptions"]["TransitionTime"], false) { nextFrame(view) }
                            return true
                            else
                            puts "End of loop"
                            return false
                            module Inteloide
                            def self.stop_animation()
                            end`
                              You've made it iterate itself!
                              Try something like this...
                              def initialize()
                                @model=Sketchup.active_model
                                @pages = Sketchup.active_model.pages
                                @po=@model.options["PageOptions"]
                              def nextFrame(view)
                                while view
                                  @pages.to_array.each_with_index{|page, i|
                                    next unless page.name==page.label ### (SKIP)
                                    puts page.name
                                    @pages.selected_page = @pages[i]
                                    UI.start_timer(@po["TransitionTime"],false){###}### wait for a time
                                end#while
                              or similar...
                                inteloide
                                Well, I'm lost ;o)
                                what is the aim of this loop :
                                what do you put instead of "###" in the code :
                                (I put nextFrame(view) because if not the animation doesn't continue)
                                  inteloide
                                  Maybe it's because I don't understand how sketchup makes the loop for an animation, what's happen after nextframe is called and run ? I'm lost in fact.... ๐Ÿ˜ฎ(
                                    Maybe I confused you with the addition of
                                    All this does is NOT display the page IF the name and label don't match.
                                    A page's name and its label are the same UNLESS the page has be marked NOT to be included in the animation in the Scene-Manager dialog - it then has the name labeled inside () - so you won't show it...
                                    The ### is a 'rem' statement - a 'comment' after the code so what follows is ignored...
                                    The next part:
                                    puts page.name
                                    simply displays the name of the scene it's processing in the Ruby Console
                                    Then:
                                    sets the selected page to be the current pages 'item' [by index 'i'] in the list of pages...
                                    Next:
                                    The timer starts a pause - the rem ### at the end is as above...
                                    ON reflection... I appreciate that this final part is wrong. ๐Ÿ˜ฎ
                                    Because the timer then runs outside of the main loop !
                                    Perhaps using:
                                    sleep(@po["TransitionTime"])
                                    instead, might work instead ?? This stop processing for that long before the next page is set 'selected'. ๐Ÿ˜•
                                      inteloide
                                      I didn't saw your answer but I produced this code...
                                      I post it for your information...but I will work on your answer
                                      So, my code, as it is now (please don't blame me using a global variable... ๐Ÿ˜‰ )
                                      def initialize
                                      puts "Start of animation v1"
                                      @p=0
                                      @id=0
                                      def nextFrame(view)
                                      if $inteloide_cont==true then
                                          @p+=1
                                          @id=UI.start_timer(Sketchup.active_model.options["PageOptions"]["TransitionTime"]+Sketchup.active_model.options["SlideshowOptions"]["SlideTime"], false) { nextFrame(view) }
                                          return true
                                        else
                                          puts "End of loop"
                                          return false
                                      else
                                        puts "stop animation"
                                        @id=UI.start_timer(1, false) { nextFrame(view) }
                                      module Inteloide
                                      $inteloide_cont=true
                                      $inteloide_cont=false
                                      def self.pause_animation()
                                      $inteloide_cont = !($inteloide_cont)
                                      puts $bg_cont
                                      end`
