    NOT A Spaceship
    13 Posts 4 Posters 636 Views 4 Watching
    • Bryan KB Offline
      Taking a break from the colony ship.
      SU and 2 Kerky renders.
      • Bryan KB Offline
        I would welcome some lighting suggestions. I'm not getting the results I want or should.
          Did you try using an IBL?
          I'm not too familiar with KT but I've seen other using them.
          There's also this tut that can be applied to just about any render app
          http://www.cgarena.com/freestuff/tutorials/max/studiolighting2/index.html
          Make a studio with emitter placed around it to light you model with nice reflections.
          • Bryan KB Offline
            πŸ˜† It was a material problem with the background. DOH!
            • Bryan KB Offline
              Thanks for the link and suggestion, Rich.
              What is IBL?
                Image Based Lighting
                You use an image to light the scene rather than lights.
                http://i.minus.com/jZQeSpkpUd80A.png
                This is lit by this....
                suc-studio-1.zip
                • Bryan KB Offline
                  Ah. Excellent. Thank you. Great example.
                  Sheesh. I'm such a neewbie. And at my age. πŸ˜†
                  • Bryan KB Offline
                    Minor tweaks update. Door spacing. Soften shadows. SU model cleanup.
                    • novenaN Offline
                      novena
                      hi Bryan, it is looking nice!
                      in my opinion the corner where floor and wall meet should be rounded like in the tutorial linked by Rich, the use of HDRI is also a good idea (im not familiar with KT either)
                      here comes another tutorial with concepts that should work with any application:
                      http://cg-india.com/Tutorials/V-Ray/3dsMax_tutorial_SL_01.html
                      best
                      V
                      http://hdzarkitektur.wordpress.com/
                      • massimoM Offline
                        massimo Moderator
                        If you use a HDRI in KT remember to set "Linear Lighflow" to "off": settings-->advanced-->scenes-->"my scene" (the name of the scene)-->default global settings-->right click on "linear lighflow".
                        • Bryan KB Offline
                          Thanks massimo and novena.
                          Massimo, I'm currently limited to the HDRIs that came with Kerky as I don't know how to make my own. I know how to include a photo image in Kerky and theoretically how make a curved image, but that's the limit of my knowledge at this time.
                          Great tip on the sun settings!
                          Here's some playing around with materials and also rebuilt the cyclorama. The black line in the background is function of the material used on the cyc. (chrome)
                          • massimoM Offline
                            massimo Moderator
                            You can load whatever HDRI you want in KT. If you use a HDRI for this kind of scene, disable the sun.
                            • Bryan KB Offline
                              Thanks again massimo. Best explanation I have ever seen.
                              I'll give this a try this week and post again.
