    NOT A Spaceship
    13 Posts 4 Posters 781 Views 4 Watching
    • Bryan KB
      I would welcome some lighting suggestions. I'm not getting the results I want or should.
        Did you try using an IBL?
        I'm not too familiar with KT but I've seen other using them.
        There's also this tut that can be applied to just about any render app
        http://www.cgarena.com/freestuff/tutorials/max/studiolighting2/index.html
        Make a studio with emitter placed around it to light you model with nice reflections.
        • Bryan KB
          πŸ˜† It was a material problem with the background. DOH!
          • Bryan KB
            Thanks for the link and suggestion, Rich.
            What is IBL?
              Image Based Lighting
              You use an image to light the scene rather than lights.
              http://i.minus.com/jZQeSpkpUd80A.png
              This is lit by this....
              suc-studio-1.zip
              • Bryan KB
                Ah. Excellent. Thank you. Great example.
                Sheesh. I'm such a neewbie. And at my age. πŸ˜†
                • Bryan KB
                  Minor tweaks update. Door spacing. Soften shadows. SU model cleanup.
                  • novenaN
                    novena
                    hi Bryan, it is looking nice!
                    in my opinion the corner where floor and wall meet should be rounded like in the tutorial linked by Rich, the use of HDRI is also a good idea (im not familiar with KT either)
                    here comes another tutorial with concepts that should work with any application:
                    http://cg-india.com/Tutorials/V-Ray/3dsMax_tutorial_SL_01.html
                    best
                    V
                    http://hdzarkitektur.wordpress.com/
                    • massimoM
                      massimo Moderator
                      If you use a HDRI in KT remember to set "Linear Lighflow" to "off": settings-->advanced-->scenes-->"my scene" (the name of the scene)-->default global settings-->right click on "linear lighflow".
                      • Bryan KB
                        Thanks massimo and novena.
                        Massimo, I'm currently limited to the HDRIs that came with Kerky as I don't know how to make my own. I know how to include a photo image in Kerky and theoretically how make a curved image, but that's the limit of my knowledge at this time.
                        Great tip on the sun settings!
                        Here's some playing around with materials and also rebuilt the cyclorama. The black line in the background is function of the material used on the cyc. (chrome)
                        • massimoM
                          massimo Moderator
                          You can load whatever HDRI you want in KT. If you use a HDRI for this kind of scene, disable the sun.
                          • Bryan KB
                            Thanks again massimo. Best explanation I have ever seen.
                            I'll give this a try this week and post again.
