    [Plugin] TIG-Split_to_plane v1.1 20130107
    25 Posts 17 Posters 36.5k Views 17 Watching
    • TIGT
      TIG (c) 2013
      TIG-Split_to_plane.rb
      Installation: Place this file in the Plugins folder and restart Sketchup.
      Usage:
      Plugins menu > 'TIG-Split_to_plane' or with a suitable selection use the context-menu 'TIG-Split_to_plane'
      Note: for Pro >=v.8 only...
      Preselect a 'solid' object [group or component_instance].
      Activate the tool.
      Follow the prompts and pick 3 points to define a plane.
      If you press <Enter> rather than picking the 3rd point the plane is assumed to be vertical, passing through points 1 and 2.
      If points 1 and 2 are aligned vertically and you press <Enter> theres an error message and you need to pick point 3, OR abort, say by pressing <Spacebar>.
      The selected object will then be split along the defined plane.
      The two new part-groups made from the 'split' operation retains the original object's locked/hidden-state, shadow-casting/receiving-behavior, name*, material, layer and any attribute-dictionaries attached to it.
      *If the original was a group the 'split' groups take its name, if it was a component-instance the 'split' group takes its definition name, but if that instance also had a name then this is appended to the new name inside [].
      The two parts are also given a suffix to differentiate them - '-A' or '-B'.
      The 'splitting' is one step undo-able.
      Donations: PayPal.com info @ revitrev.orgPayPalButtonVersion:
      1.0 20121007 First issue.
      1.1 20130107 Now at Point 3 an alternative <Enter> press splits vertically.
      Context-menu if selection suitable.
      Read and follow the instructions...
      • J
        jorge2011
        exelente. thank you very much 😄
        • T
          Trogluddite
          That's brilliant, thanks TIG.
          Beautifully simple to use - yet another of your creations that makes me think "Why wasn't that in the standard toolbox all along?"
          • B
            Ben Ritter
            TIG, thank you, for both of these plugins.
            • gillesG
              gilles
              May I suggest to add [ProV8] to [Plugin] so free users are aware of the restriction?
              • R
                rilian
                Seems like both plane tools would be very useful. Too bad they don't work on the free version.
                • guanjinG
                  guanjin
                  Good tool, if the shape of the cut is even more useful。
                  I come from China, is to learn
                  • T
                    tulacong
                    oh zeee...thank you
                    • simon le bonS
                      simon le bon
                      Dear Tig,
                      This is the 101 eme tool links I bookmark coming from you !!!! 🎉 😄
                      Each are useful, some are absolutely unavoidable, the suite tools are always stunning 👍 👍 👍
                      Thank you for this new one +++
                      Simon
                      • kingsiK
                        kingsi
                        Thanks for the Ruby TIG
                        Noobtastic
                        • bagateloB
                          bagatelo
                          I see fantastic tool for this in the future. Line to cut solids.
                          • TIGT
                            Here's v1.1 http://sketchucation.com/forums/viewtopic.php?p=433732#p433732
                            Also Context-menu if selection suitable.
                            • cottyC
                              cotty
                              +1 👍
                              my SketchUp gallery
                              • K
                                KE6CVH
                                Hi, I'm getting ready to download and try the awesome plugin but see where recommendations twice have been made to put proV8 on it so people know restrictions. Does that mean it will not work with version 8 free? If it works with free then I'll give it a try immediately for a much needed sketchup task. Thanks, Mike ☀
                                • TIGT
                                  As it says early on in the tool's download page notes in bold "Note: for Pro >=v.8 only..."
                                  It uses API solids-methods only availed in Pro.
                                  Sorry...
                                  • S
                                    smicha
                                    TIG,
                                    Splitting removes co-planar edges. Is it possible to add extra option to prevent the plugin from deleting the edges?
                                    Sebastian
                                    BTW. This plugin is just a miracle 😄 Now I cannot work without it.
                                    https://lh3.googleusercontent.com/-AoXjt9ys_Os/UTHF3a5WnMI/AAAAAAAAC70/uHBY-OPLKVU/s853/splittoplane.jpg
                                    • TIGT
                                      @Smicha
                                      Unfortunately this tool uses the API's solid-methods, which always remove coplanar-edges from any coplanar-faces sharing a material [even when one is reversed!]: so it's an unavoidable side-effect.
                                      If alternate coplanar-faces have different materials then their coplanar-edges are kept.
                                      But then redrawing a few edges, or using my 'SplitSausage'/'SplitDonut' tools to reinstate the removed coplanar-edges, is done quickly enough...
                                      • S
                                        smicha
                                        Thanks TIG for reply. I just figured out the proper way of using SplitSausge and this helps a lot.
                                        • BoxB
                                          I've noticed an occasional oddity with this Tig, sometimes the split produces one half and a whole.
                                          I'll add the model in case you can see what it is about this component that makes it happen.
                                          Split.skp
                                          • TIGT
                                            The problem object has several small facets forming the rounded parts.
                                            I suspect this is the issue.
                                            If a 'solid-tools' operation [done manually or in code] fails because tiny edges don't get made and a face is missed out, then usually it bales out with an error.
                                            It's failing to fail properly !
                                            The way the 'split' tool works is that a copy is made on top of the original instance, then a large 'block' group is made to one side of the defined 'plane' and it is then subtracted from the original; next another large 'block' group is made to the other side of the plane and subtracted from the copy.
                                            If all goes well you should get two solid groups abutting at the defined 'plane'.
                                            In your case, one side fails to be made and the subtract tool bales out leaving one of the instances unchanged, sometimes it will make the other part 'solid', but oddly it doesn't always make it as a 'solid' group on the partially successful side either - try a few tests and check it in Entity Info...
                                            The solid-tool's subtract should fail but it doesn't in this occasional odd case !!
                                            • 1 / 2
