    Fix Shadows has disappeared
    6 Posts 3 Posters 389 Views 3 Watching
    • hellnbakH
      hellnbak
      For some strange reason "Fix Shadows" has disappeared from my toolbars, and is not listed under any of the menus. Can anyone offer any suggestions on how I might get it back (short of re-installing SU)?
      Also, is there any way to perform a search for something and narrow the results down a bit? When I searched this forum for "fix shadows" I got almost 1,000 results, mainly because there was no way to tie the two words together and limit the results.
        View > Toolbars > Shadow String Fix
        at the very bottom of the list
        • hellnbakH
          hellnbak
          That was the very first place I looked. It's no longer there, nor is it listed under any of the menus. I suppose it may come back at some point, a lot of SU problems seem to fix themselves just to increase my frustration level.
            Are you using v8 or v7?
            Shadow Fix is only in v8 M2 i think?
            The fact it's not on your menu suggest you're not running the version with the fix
            • thomthomT
              Is it enabled under Extensions?
              • hellnbakH
                hellnbak
                Huh. It was not. Don't understand how that happened, I haven't messed with any extensions in quite a while. Oh well, it's back now, and all is right with the world (except for maybe a couple of things -- the economy, congress, the environment......)
                Thanks much
