    ? about wireframe effect
    16 Posts 4 Posters 855 Views 4 Watching
      Rose123
      http://i83.photobucket.com/albums/j320/DrawMeAPicture/car.jpg
      i found the above model in the Warehouse. How is that wireframe effect made? It's not just a view, because it shows up as "shaded with textures" in face style, and the wireframe view makes it even more complicated. Was a plugin used for it?
      And about plugins -are they mostly for the Pro version, or are there good ones for the free version? Does Kerkythea only work with Pro?
        Kerky is free for everyone Pro or Free
        That style is probably as a result of using Thomthom's quad face tools to soften/smooth the diagonals.
          Rose123
          Thx for the response, ok, so it IS done with a plug-in, then (Thom Thom). About Kerythea, I understand it's free for everyone, but does it work well with the free version of SketchUp? I was under the impression that it, along with most plugins, just work with the Pro version.
            Rose123
            Rich, I cross-posted -ok, so K. works as well with the free version of SketchUp, then, as do most plugins? Ok, thanks!
              Aerilius
              Plugins are made by users or third party companies (some are commercial). The ability of running Plugins is in the Free version (almost) equal to the Pro version (except of native Solid tools). That's great! Also some plugins by the SketchUp Team are exclusive for Pro licensees.
                Very few plugins are Pro only. Most that are Pro only relate to SketchUp's solid tools.
                Kerky is a great tool but the learning curve is steep.
                If you're new to rendering then something like Twilight or Podium are more accessible.
                  Rose123
                  Another question -so is that car not a true wireframe model, just a model with curved lines added to it with Thom Thom? I guess you can't do a wireframe model in free SketchUp? Can one be done with Pro?
                    The wireframe effect can be activated via View > Hidden Geometry
                    But in this example it looks like the modeler applied certain 'hiding' techniques the diagonal edges.
                    Here's a test for you to try....
                    Go to Draw > Sandbox
                    Draw a large grid
                    Now go to View > Hidden geometry
                    See how there are diagonal lines hidden. This was used it the car model to create a false quad type effect.
                    • massimoM Offline
                      massimo Moderator
                      If you want a wireframe effect you can do this way:
                      1)select with a triple click the model.
                      2)right click-->soften/smooth edges and drag the slide to "0".
                      What Rich meant is that the image you posted has no diagonals and since SU works with planar faces most probably that plugin was used in order to hide those edges.
                        Rose123
                        Thanks, I will do that! BTW, I just loaded Thom Thom but can't open it ...Windows doesn't recognize what program should be used ... what am I overlooking? Sorry for all the questions! I'm new to plugins.
                          Rose123
                          Thanks, Massimo! So again, it seems it's not a true wireframe, just a model with a wireframe affect. Wonder what the purpose of that is, just aesthetics?
                            ok, Thomthom isn't a plugin. He's a crazed criminal from Norway that writes plugins.
                            You're trying to run before you can walk. Tell us what you want to achieve and we'll walk you through it.
                              Rose123
                              lol, ok, I think I actually downloaded code from his site, not a plugin. What am I trying to do? Nothing in particular, just get up to speed with all of this really fast. πŸ˜„
                                Slow down. Learn the base SketchUp first then become the overlord.
                                See you in 3 years πŸ˜‰
                                  Rose123
                                  I just checked out Podium -if I'm reading this correctly, there are even plugins for plugins (e.g., omnigrid for podium) lol, is that correct?
                                    Download the trial and have a play. I think the omni grid comes as a component within the tool to place light throughout your model.
