    [Plugin] LSS Toolbar 2.0 Beta
    68 Posts 39 Posters 78.1k Views 39 Watching
    • K Offline
      kirill2008
      Small Announcement (29-Jan-2017)
      Note that currently there are no plans to continue development of LSS Toolbar extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.
      Link to download lss_toolbar_2_0_beta.zip
      [flash=560,315:1rff2w3e]http://www.youtube.com/v/-Nv0lV94O5Y?version=3&hl=ru_RU[/flash:1rff2w3e]
      LSS Toolbar is a SketchUp extension. It provides a set of tools for advanced geometry creation and manipulation.
      Installation
      • download lss_toolbar_2_0_beta.zip
      • unpack contents of «Plugins» subfolder into SketchUp «Plugins» subfolder
      • unpack contents of «Resources» subfolder into SketchUp «Resources» subfolder
      Toolbar Enabling
      • Sketchup Main Menu>> Veiw>> Toolbars>> LSS Toolbar
      Note
      • current version runs under Windows only
      • some certain tools conflict with SketchyPhysics plugin
      Visit LSS Toolbar web-site for more information
      Ver. 2.0 beta 1
      Link to download lss_toolbar_2_0_beta_1.zip
      • non-decimal model units fix
      • obtain point cloud added
      Ver. 2.0 beta 2
      Link to download lss_toolbar_2_0_beta_2.zip
      • control curve for '2 Faces + Path' tool added
      Installation package without user manuals
      • V Offline
        victor hugo
        Hello When I select the "make 3D Mesh" I get this error.
        file:///C:/Program%20Files/Google/Google%20SketchUp%208/Resources/en-US/lss_toolbar/pnts2mesh.html
        Is this a bug or conflict with other plugins?
        Thanks.
          Did you follow the instructions of extracting the different content to the correct folders?
            This tool has an unusual set of files - one set that go into the Sketchup.../Plugins folder and another set that go into the Sketchup.../Resources folder...
            It could have been contrived more appropriately...
            However, it is clearly spelled out in the tool's download page...
            Incidentally, you'll need to have FULL security-permissions to write files into both of these folders for this installation to be effective...
              sherwood11
              Just an observation, note or a bug ? with the Follow Edges tool ...
              I was continually getting this message [below] with the units format (in Model Info) set to 'Architectural'.
              It works much better with the units format set to 'Decimal' ...
              My unit measurement is set to inches.
              • K Offline
                kirill2008
                It is a bug... And I'm afraid this error will raise in other tools as well with the units format (in Model Info) set to 'Architectural'. Thanks for reporting 👍
                • X Offline
                  xrok1
                  WOW! Looks like an awsome addition! 😄
                  “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                    schnydix
                    Thanks so much Great stuff
                    now i can easy create my coral reef
                      Seems a new true geometric gem 😄
                      fractal plugin is not so frequent 😉
                        tulacong
                        thank you very much
                        • EarthMoverE Offline
                          EarthMover
                          All the tools are great. The voxel tool is really cool, albeit buggy. I love that you can pick a component instance and fill a volume with it. It essentially becomes a scatter tool. Will be great for making plants, etc.
                          Content Creator at Skapeup
                          • N Offline
                            notareal
                            👍 Impressive work!
                            • srxS Offline
                              srx
                              www.saurus.rs
                              • majidM Offline
                                majid
                                is there any conflict by Fredo06's truepaint?.... it is not working anymore...
                                Edit: removed the LSS toolbar and it;s components and fredo06 truepaint works again 😢
                                  schnydix
                                  Again a nice work Thanks for the hard work
                                  Itis possible switch off parts of the tool like voxelizer
                                  • I Offline
                                    I.Aleks.S
                                    Уважаемый kirill2008, высокая оценка за труды на благо сообщества!
                                    скажите есть-ли русская версия вашего LSS Toolbar, Вы ведь владеете русским?!
                                    Благодарю.
                                    • guanjinG Offline
                                      guanjin
                                      kirill 2008 Hello:
                                      First, thank you for your hard work, the development of such a good tool.
                                      There is a problem:
                                      The joint can not be changed, thank you!
                                      I come from China, is to learn
                                      • K Offline
                                        kirill2008
                                        @guanjin said:
                                        There is a problem:
                                        Looks like it caused by localization. Please open ruby console and send an error message from it, so I'll be able to find the problem.
                                        Русской версии пока что нет. Планирую исправить те недочеты, которые выявятся в ходе тестирования бета-версии, после этого приступить к локализации.
                                        That's strange. LSS Toolbar does not override any methods, so it may be blocked itself by other plugins (like SketchyPhysics, which overrides 'copy' method of 'Group') but it's very unlikely that LSS Toolbar blocks other plugins...
                                        Anyway, you may temporarily disable LSS Toolbar without uninstalling it. LSS Toolbar is an extension (you can assume that extension is a kind of manageable plugin), so you may uncheck it in 'System Preferences' dialog instead of removing of all files and folders:
                                        It is a temporary solution, of course. Please, send report from ruby console when truepaint refuses to work with LSS Toolbar enabled, so it will be possible to find out what is the problem.
                                        Good news: here is a bit fixed version https://dl.dropbox.com/u/44695539/lss_toolbar/lss_toolbar_2_0_beta_1.zip
                                        It works better with non-decimal model units plus it has some new functionality:
                                        [flash=560,315:dx5szeyq]http://www.youtube.com/v/zuNA_Lr5gyQ?version=3&hl=ru_RU[/flash:dx5szeyq]
                                        • guanjinG Offline
                                          guanjin
                                          Thank:kirill2008
                                          Simple and convenient tool, I will continue to test!
                                            driven
                                            Hi Kirill,
                                            left a note on your blog, but thought I write here as well.
                                            Webkit reported errors so I changed lss_common.js, just syntax
                                            function apply_defaults(){
                                            	for (i=0; i<settings_arr.length; i++) {
                                            		var img_btn=document.images[settings_arr[i][0]];
                                            		if (img_btn) {
                                            			if (settings_arr[i][1]=="true") {
                                            				img_btn.setAttribute("className", "btn_checked");
                                            			else {
                                            				img_btn.setAttribute("className", "btn_unchecked");
                                            		var input_ctrl=document.getElementById(settings_arr[i][0]);
                                            		if (input_ctrl) {
                                            			if (input_ctrl.type == 'text') {
                                            				input_ctrl.value=settings_arr[i][1];
                                            			if (input_ctrl.type == 'checkbox') {
                                            				if (settings_arr[i][1]=='true'){
                                            					input_ctrl.checked=true;
                                            				else{
                                            					input_ctrl.checked=false;
                                            also @index_path="file://#{@resource_dir}/lss_toolbar/instruct/index.html" was needed to open help in Safari.
                                            Changed show()to show_modal() for mac use.
                                            Seems to be a couple of other minor glitches that I'm finding, but they may be me not being familiar with the process.
                                            The other major problem is SU crashes on quit with this activated in 'Extensions' but not when it's not... No other plugins/extensions active when testing.
                                            When it's activated, SU asks to 'Save Changes' on quit, whether I used it or not, then crashes as it closes it's windows.
                                            If I first close a drawing, I get the save dialog, which I can close without saving. after that SU will quit without a crash report.
                                            john
                                            • 1 / 4
