    [Plugin] Material Renamer
    29 Posts 12 Posters 35.0k Views 12 Watching
    • shannakaeS Offline
      shannakae
      @jolran said:
      and when I add the component into my model it also brings in all the new generic colors that further clutter up my materials library..
      I hate to ask. You do do know you can purge unused materials ?
      In case not. In the Materialpalette, click the house to get to modelmaterials.
      The icons furthest to the right(blueish) click and choose purge unused.
      Otherwise there is maybe this:
      404 Not Found
      (sketchucation.com)
      or this ?
      404 Not Found
      (sketchucation.com)
      Take care.
      Thanks, i will look those up. I do know about purge un-used (but I did just learn about it the other day so you are not so far off 😉 )Thanks! I will look up the two topics and see if there is something there that works for me... I was looking at the open or create a collection section... and was going to explore how that might work for what I am trying to do...
      • bagateloB Offline
        bagatelo
        @bagatelo said:
        @tig said:
        ...it would be possible to get the base name for the materials from file skp name automatically?
        Yes, where the earlier code says
        m.name = "mat#{'%03d' % i}"
        change it to read
        m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"
        GREAT!!! Thanks...
        Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "#{Sketchup.active_model.title}#{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
        I want to add a shurtcut for this function. Can you make a plugin for me, please? 😳
        • CadFatherC Offline
          CadFather
          def matrename
          Sketchup.active_model.start_operation('Rename Materials',true); Sketchup.active_model.materials.each_with_index { |m,i| m.name = "- #{'%03d' % i}"; p m.name };Sketchup.active_model.commit_operation
          if( not file_loaded? "TT_materials_renamer.rb" )
          UI.menu("View").add_item("Materials Rename") { matrename.new }
          file_loaded("TT_materials_renamer.rb")
          • bagateloB Offline
            bagatelo
            @cadfather said:
            > def matrename
            > end
            > end
            Great! Thanks!
            One thing that would be really interesting would be that this script index materials application in areas with higher per square meter first. Thus, a material that was on all the walls would be in first place. A material that was in small areas (a decorative object for example) would be the end of the numbering.
            • H Offline
              harvey1
              Is it possible for this plugin to allow one to rename individual materials. For example, let's say my model is imported into SU as Material 1, and I'd like to rename it Window, and Material 2 to be renamed Door, etc.
              • P Offline
                Pherim
                This plugin appears to be buggy for me... it seems to be applied as soon as Sketchup has started, so when I open a file by double-clicking it in explorer, the materials get renamed immediately. The same happens when I activate the plugin via the Sketchucation Plugin Store. Will leave it deactivated until the cause is found...
                • JBJDesignsJ Offline
                  JBJDesigns
                  Currently, I have this plug-in disabled (i.e., "tt_materials_renamer.rb" to "tt.materials.renamer.rbDISABLE"). Is there a way to turn this option on or off as needed. Many of my projects are uploaded into Vue 10 Esprit for rendering. I've been "building" a database of materials from SU. When the files are automatically renamed to "mat00", "mat01", etc., it's near impossible to determine whether the material has been saved to it's converted ".mat" format. Your help is appreciated. Jo Ann 😄
                  ...you send them to school, you give them books, and they eat the pages...
                  • R Do not disturb
                    rv1974
                    Beware: It runs silently in background on the file opening! I managed to spoil a couple of files with this one 😳
                    It should be written on the top.
                    • designerbursaD Offline
                      designerbursa
                      Plugin name and menu text
                      PLUGIN_NAME = 'Rename Materials by File Name'.freeze
                      Plugin class
                      class RenameMaterials
                      def self.rename
                      # Get the active model
                      model = Sketchup.active_model
                      # Get the file name and remove the extension
                      file_name = File.basename(model.path, ".*")
                      # Get all materials in the model
                      materials = model.materials
                      # Iterate through all materials and assign new names based on the file name
                      materials.each_with_index do |material, index|
                        new_name = "#{file_name}_#{format('%02d', index + 1)}"
                        material.name = new_name
                      puts "Materials have been successfully renamed based on the file name."
                      Menu item that activates the plugin
                      UI.menu('Plugins').add_item(PLUGIN_NAME) { RenameMaterials.rename }
                      • 2 / 2
