    Help with making my wire mesh material white.
    renderpluginsextensions
    6 Posts 3 Posters 2.3k Views 3 Watching
      Moshtark1
      Hello evey body. I am trying to make a wire mesh for an elfa basket. I would like to make the material white but at the moment I am only able to make a metalic like material.
      What am I missing here have played with every setting I can think of? ( apart from, probarly the most obvious )
      Thanks all
      wire mesh.vismat
      ELFA_SYS_35_MESH.skp
        Moshtark1
        Sorry guys, have it under control using invert in the difuse layer, transparency. Silly me.
          Roger
          Just fooling around with some textures. Was this the direction you were thinking of going? Were you going to stay in SU or run it through a render engine? The problem is that mats cast a solid shadow or no shadow, but it would take a lot of post to cast the actual shadow of the mesh.
          Elfa test
          http://www.azcreative.com
            Roger
            Now that you have it solved could you show the result?
              Moshtark1
              Thanks for your intrest Rodger. It is a very tight mesh, and yes I have put through vray. I think it will do all I need it to do without all the polyons.
              • fuzzionF Offline
                fuzzion
                Yeah best to use vray material for this.
                "Only the dead have seen the end of war" - Plato
