    Followme problem with semi circle
    4 Posts 3 Posters 936 Views 3 Watching
    • P Offline
      PRSS
      Hello everybody
      I have attached two images and the skp file also. My staff is learning sketchUP and she was trying to do an exterior view of a dining cabinet. When she tried to do the half round nosing using a semicircle as followme, sometimes she gets results with a lot of lines on the curved surface, sometimes there are no lines on the curved surface. The methodology used is the same. Can anybody help in finding out the problem. I too tried this out with the same results.We are using Su 7.1 on Windows XP-SP3.
      Thanks in advance
      PRSS
      There are two screen shots and the skp file
      • jenujacobJ Offline
        jenujacob
        hi PRSS,
        i think its exploded curve that causes the lines...
        u can fix it by using the WELD plugin.
          As has been said...
          Curves give smooth Surfaces when extruded with FollowMe or PushPull etc.
          Curves include Arcs, Circles and Curves made by scripts like Bezier-Curves and any collection of Edges joined using Weld [or some other similar tools, e.g ReCurve].
          A Curve is just a collection of Edges bound in a special way - e.g. they always Select/Erase as if they were one object.
          The created Surface will still have Edges at changes of plane, but these are automatically 'Smoothed'.
          If you change your View > Hidden Geometry toggled 'on' you'll see them dotted.
          Note that these are not quite the same as 'hidden lines', which will leave a sharp change in shading at that Edge - Smoothed/Softened Edges just 'shade' more smoothly...
          If you Explode a Curve it becomes a set separate of plain Edges.
          Any other collection of plain Edges will extrude and leave visible Edges in any new Surfaces.
          To change this either Weld these Edges into a Curve before extruding using it, or afterwards you can Select the Surface and right-click context-menu 'Smooth'...
          Note how you can also reverse a Surface's Smoothing by sliding the control in the 'Smooth' dialog towards 0, which can also have it's uses.
          You can Smooth individual Edges at any time by using the tool Erase+Ctrl.
          You can also Hide an Edge [see above regarding the differences] using Erase+Shift and unhide them [assuming Hidden-Geometry is 'on'] using Erase+Shift+Ctrl.
          Selected Edges can also be Hidden/Unhidden usig the right-clcik context-menu.
          There is no equivalent 'Unsmooth' - however, if Hidden-Geometry is 'on' you can Select Smoothed Edges and using Entity Info change their Smooth/Soft status [and also their Hidden status too].
          • P Offline
            PRSS
            Thank you jenujacob and TIG. This has really solved my problem - that is by welding - though I knew all the other techniques which TIG has kindly narrated. Thanks again to both of you.
            jenujacob ! Nice to hear from you after a long, long, time!
            With best regards
            PRSS
