    [Plugin] Divide Angle v1.0.1 20130621
    22 Posts 17 Posters 19.4k Views 17 Watching
      (c) Copyright TIG 2012-2013
      You may not use, copy, modify, or distribute this software for
      any purpose, without the express prior agreement of the copyright holder:
      this full copyright notice must appear in all copies.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
      IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
      WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      #TIG-divide_angle.rb [manual-install put into the Plugins folder and restart Sketchup]***
      Usage:
      Select two edges that are not parallel and that could intersect if they don't
      already share a vertex.
      Right-click to get the context-menu 'Divide Angle...'
      Note how this context-menu item is only available if the selection is appropriate.
      In the dialog enter the number of divisions + OK [default is '2'].
      It must be a positive integer [2 NOT 2.0]; otherwise you are prompted to retry.
      Also it must be 2 or more; otherwise there's an error message and it exits.
      Guide-lines are now drawn through the two selected edges and the division[s] as
      you have specified.
      The angle between the edges that is less than 180 degrees is always divided.
      Donations:
      by PayPal.com to info @ revitrev.orgPayPalButton###
      Version:
      1.0 20120803 First release.
      1.0.1 20130621 Added to Plugin Store.
      ***Now available from the PluginStore http://sketchucation.com/resources/pluginstore?pln=TIG-divide_angle
      or AutoInstall and manage it using the Plugin Store toolset. http://sketchucation.com/resources/plugin-store-download
        rv1974
        Outstanding!!!
        • cottyC Offline
          cotty
          Thank you, nice little helper.
          And a little visual example:
          my SketchUp gallery
            Ben Ritter
            Thank you. You are kind, and generous.
            • KrisidiousK Offline
              Krisidious
              You Sir are a Rock Star...
              By: Kristoff Rand
              • alexschreyerA Offline
                alexschreyer Extension Creator
                That's a neat helper functionality. I also like the idea of having something like that in the next release as a preference setting.
                Cheers,
                Alex
                Author of "Architectural Design with SketchUp":
                http://sketchupfordesign.com/
                • massimoM Offline
                  massimo Moderator
                  Thanks TIG. πŸ‘
                  • pbacotP Offline
                    Wonderful!
                    • utilerU Offline
                      utiler
                      That's cool, TIG! Til now I have drawn a cline, copy/rotated it and divided by how ever many divisions I needed.... πŸ‘
                      Just Curious...
                      • ElibjrE Offline
                        Elibjr
                        Sir, you are a mastermind that makes masterpieces. Thank you!
                        • simon le bonS Offline
                          simon le bon
                          added to basic tools.
                          Thank you Dear Tig++
                          simon
                            Thank you, sir.
                            Is there a metric version? πŸ˜† Gets hat, coat....
                              It's based on a sort of sexagesimal - base 60 - version.
                              660 = 360 degrees in a circle NOT 100...
                              Then it's all calculated in bloody Radians - 2
                              PI in a circle...
                              BUT you enter a ratio anyway πŸ˜• πŸ˜• πŸ˜•
                              2 or 3 or 4 etc...
                              πŸ€“
                                Lobster
                                Thanks,
                                Most useful
                                  smicha
                                  TIG,
                                  This plugin is great but not listed in the plugin store πŸ˜„
                                    It will be... πŸ˜„
                                      I have missed this one! 😲
                                        Now added to the PluginStore list...
                                          tabulador
                                          Muchas gracias, amigo
                                            mirshahi
                                            I installed the RBZ file in SU Pro 8 and it does not load. I check the extensions, manually downloaded the extension, still does not show in the Ext. list and, of course, it does not load.
                                            What is the problem???
                                            • 1 / 2
