    Color; Highlighted space or making light
    9 Posts 4 Posters 414 Views 4 Watching
    • dukejazzD Offline
      dukejazz
      Giving objects a locolize regions of box, spear, cone, dome or other primitives that has a foregound or backgound a color with noise, shine, matted line, colors with transparency gives a glow to a highlitghted objects region of space. Work best with tile or random small color textures.
      This is a highlighted space for a objects.
      More Examples:
      http://forums.sketchucation.com/viewtopic.php?f=323&t=45254
      • dukejazzD Offline
        dukejazz
        Masking the space
        back view (note the spear is solid)
        side view
        front view
        Now it should be clear what a highlighted space is and how it can be textured
        • dukejazzD Offline
          dukejazz
          both sides rev and front transparency worked here
          with mask
          • dukejazzD Offline
            dukejazz
            Highlighted space: 100% sketchup done with X ray mode in layers
            highlighted space. 100 % sketchup X ray .skp
              Your posts are very confusing. I don't understand what you are doing here or why. It's like you started in the middle of a sentence. Why would you use this? There's no good explanation. Is this a setup for rendering in some rendering program?
              I don't see a spear anywhere in your images.
              What does the sphere have to do with these transparent boxes? Why do you have a cube painted with transparent material? If you want to create the appearance of light through the opening, wouldn't a single face work just as well?
              Please clarify and make this a useful tutorial. If you do that, I'll move it to the tutorials section.
              • jeff hammondJ Offline
                jeff hammond
                πŸ˜„ πŸ˜„
                i think it's an attempt at making the spear look like it's glowing (the 2nd to last image posted prior to me posting.. the one with a sphere inside the building while looking through the window.. it looks as if this lightbulb/sphere is lit and glowing more-so than if you just put a sphere inside a building.
                dotdotdot
                  I've looked again and I still don't see a spear anywhere. ❓
                    Perhaps 'spear' is a typo of 'sphere' ?
                    There is one of those πŸ˜‰
                      Ah, yes. I see. I was reading it too literally. πŸ˜’
