    Curviloft -HELP
    7 Posts 3 Posters 499 Views 3 Watching
    • W Offline
      wantj43
      I've read and re-read the various threads about installing and activating curviloft. It appears all the required files are in the plugging folder, but still nothing. PLEASE - HELP!
      Joe
        You have got the required 'FredoLib' folder of support files etc, haven't you?
        Can you post a screen-shot your 'plugins' folder/subfolders/files...
        Remember that the 'plugins' folder should be the one in the Mac HD 'root' lib folder path and not a 'user' one.
        Also note that depending on your settings Safari can unzip things as they arrive, confusing Mac users who then try to #unpack' things further than they need to be...
        As a Newbie why aren't you trying v8 ?
        That has possibilities of automating the installation process...
        • W Offline
          wantj43
          Thank you. The downloaded files were copied then pasted to the plugin folder. I must be missing something, but, haven't been able to figure it out. Your help is really appreciated.
          • W Offline
            wantj43
            I am using version 8. Sorry, missed that part of your initial response. Again, I appreciate all the help.
            Joe
              The folder for 'LibFredo...' that is shown in your plugins folder looks like it's the 'container' - i.e. the folder that's created when you extract the zip-file's contents.
              You do not put that into the plugins folder, rather you put its contents into the plugins folder.
              So... in that folder there will be a .rb file and a subfolder with a similar name to 'LibFredo...'.
              That .rb file and the subfolder should both be in the plugins folder !
              Leave any files in the subfolder where they are - i.e. inside the subfolder, which is in the plugins folder.
              So it looks like you have not extracted the Lib's file/subfolder properly. ๐Ÿ˜ฎ
              Your Safari settings might be extracting zips as they download, which can be confusing...
              But the CurviLoft stuff looks OK ๐Ÿ˜•
              • W Offline
                wantj43
                THANK YOU - Everything seems to working fine. If you are every in Alaska and in the Fairbanks area - let me know - I owe you BIG TIME! Thank you again.
                Joe
                • P Offline
                  phoryth
                  It doesnt work with me either! I searched 3 hours now but cant find the problem.
                  I made a scrrenshot. and there seems to be a problem with the rights of administration.
                  It would be so great if someone could help me!!!
