    Aligning standard views with existing geometry
    4 Posts 3 Posters 393 Views 3 Watching
    • S
      scottthomascarter
      I need to align the standard views so that they are parallel/normal to certain faces in my model. I've tried re-aligning the axes (which I was successful at doing) but this doesn't seem to affect the behavior of the standard views (when I click top/front/side etc. buttons). The resulting views still show the model at an angle not normal to any faces.
      The entire model is based on geometry cut and pasted at from a different model, so it adopted the skewed angle of the original model's axes.
      How do I reset the standard views to certain aspects of my geometry?
      Thanks.
        Did you try selecting the face and right click > align view?
        • wind-borneW
          wind-borne
          Extended Standard Views
          "To read between the lines was easier than to follow the text."OSX 10.11.6
          %(#BF80BF)[SU 8 pro
          • S
            scottthomascarter
            I did use "Align View" which works fine for that particular moment. But I need to go back to the orthogonal views regularly. I installed the plug-in for extended standard views as suggested and it works perfectly. Seems like this really ought to be standard behavior for Sketchup. I've just replaced my standard views toolbar with it. Thanks for all of the help.
