    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    [Plugin] Ruby Console+ (3.0.2) – updated 30.10.2017
    61 Posts 18 Posters 37.4k Views 17 Watching
    • rami_lpmR Offline
      rami_lpm
      All I'm getting is this.
      Win Vista Business 64
      Java 7 update 7
      IE 7 <--- is this a problem?
        Aerilius
        That might be the problem.
        Requirements:
        for now, it works only in the Windows version of SketchUp (IE8, IE9)
        (Does Internet Explorer 7 run on Vista??)
        • rami_lpmR Offline
          rami_lpm
          Was that 'requirements' line there all the time?
          Yes, IE7 was installed with my spanish version.
          I upgraded and it works fine.
            Anton_S
            I had the same problem as in the posts before. To resolve the problem you must delete the registry of original Ruby Console +: (Windows 7)
            [list:2x1uqeh5][:2x1uqeh5]Go to start menu and search, and open regedit.exe.[/Ⓜ2x1uqeh5]
            [:2x1uqeh5]Locate registry path: Computer\HKEY_CURRENT_USER\Software\Google\SketchUp[n][/Ⓜ2x1uqeh5]
            [:2x1uqeh5]Delete the following folders and registry:
            .\Extensions\Ruby Console+[ver
            • .\Plugins_ae\Console
            • .\WebDialog_AE_Console[/list⭕2x1uqeh5]]
            After delete, it must work!
            On other windows versions, the registry might be in similiar named locations.
              Anton_S
              Other than the registry the ruby console is outstanding! 😍
              Highligh entities, beatiful script highlightings, fast processing, and much more. 👍
              I only had to go to Plugins\ae_Console\jQuery\jquery-console-extensions.js and comment out all the DEBUG "puts" sections -- It disturbed me posting "resizing", and "finish resizing".
              Now the wish! Is there a way to add a "clear history" button, so it clears all the console history input queue? To clear, i can go to registry and clear it out manually, although it would be nice to have a button.
              • Chris FullmerC Offline
                I'm so glad you explained how to remove all the resizing puts statements. I just installed this and I was already ready to never use it again until that was fixed.
                Otherwise pretty cool. Thanks!
                Chris
                All my Plugins I've written
                • rami_lpmR Offline
                  rami_lpm
                  Thanks Anton, this was bothering me too.
                    Aerilius
                    Sorry for that mistake, I fixed it!
                      Aerilius
                      Minor update (1.0.9):
                      • added icon
                        Aerilius
                        I added improvements for higher dpi settings.
                          Aerilius
                          A new version has been uploaded!
                          Ruby Console+ 2.0 is more robust, more powerful and more beautiful!
                          • renderizaR Offline
                            renderiza
                            The perfect companion for testing code thanks!
                            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                              Anton_S
                              Wow!!! 😍
                              Aerilius, you're so amazing!!!
                              Variety of style templates, bigger input zone, that's just amazing
                                Aerilius
                                An update is ready!
                                By replacing ace editor 1.1.0 by version 1.1.2, we now have auto-completion (ctrl+space) and code snippets support. I connected the autocompleter to Ruby so that it displays only completions (methods etc.) that are available in the current context.
                                http://sketchucation.com/forums/download/file.php?id=115857
                                Apart from that, modified scripts are now reloaded automatically.
                                  Anton_S
                                  Amazing update! 👍
                                  I can't wait to check it, since I'm not at my home computer now.
                                    matt.gordon320
                                    Hello!
                                    I'm getting this error. I'm using Fredo's Additional Plugin Folders script to control who in our firm has access to which plugins, just for reference. Any thoughts on what it might be?
                                    Thanks!
                                      Aerilius
                                      That is a Javascript error caused by something in ace.js (you're not getting a popup error because I redirect such errors into the console). When I integrated ace into the webdialog there were a couple of incompatibilities with IE, that I tried to patch. It seems I didn't get that one. I'll try to work-around it. Thanks for reporting!
                                      • jolranJ Offline
                                        jolran
                                        Thank you Aerilius. This one will be used a lot! Very useful.
                                        I also got that JS error at first launch. Did not hinder me to use the dialog though, so it was surpressed.
                                        This morning I did not get that error.
                                        Another thing, I have to launch the plugin twice to get dialog showing. Persistantly. Tried relaunching SU 3 times, all the same. Not a big deal, but someone impatient 😄 might Think the plugin doesent work.
                                          Aerilius
                                          The JavaScript error should be supressed in version 2.1.1.
                                          jolran, I can't reproduce it. When you open the Ruby Console+ for the first time (where it doesn't open), does something appear in the native Ruby Console?
                                          • Rich O BrienR Online
                                            Is it in the PluginStore? I see no update listed
                                            • 2 / 4
