    [Plugin] Ruby Console+ (3.0.2) – updated 30.10.2017
    61 Posts 18 Posters 44.9k Views 17 Watching
      Reind Brackman
      Just installed Ruby Console+ and my productivity doubled already.
      Also very good to avoid RSI, better known as 'lets load the damn script again command...'
      Thanks - great work.
      • C
        cesaro36
        Could anyone solve this issue?
        Same Problem
          Aerilius
          What same problem? What browser? What version of the plugin?
          Can you try the latest version?
          • rami_lpmR
            rami_lpm
            All I'm getting is this.
            Win Vista Business 64
            Java 7 update 7
            IE 7 <--- is this a problem?
              Aerilius
              That might be the problem.
              Requirements:
              for now, it works only in the Windows version of SketchUp (IE8, IE9)
              (Does Internet Explorer 7 run on Vista??)
              • rami_lpmR
                rami_lpm
                Was that 'requirements' line there all the time?
                Yes, IE7 was installed with my spanish version.
                I upgraded and it works fine.
                  Anton_S
                  I had the same problem as in the posts before. To resolve the problem you must delete the registry of original Ruby Console +: (Windows 7)
                  [list:2x1uqeh5][:2x1uqeh5]Go to start menu and search, and open regedit.exe.[/Ⓜ2x1uqeh5]
                  [:2x1uqeh5]Locate registry path: Computer\HKEY_CURRENT_USER\Software\Google\SketchUp[n][/Ⓜ2x1uqeh5]
                  [:2x1uqeh5]Delete the following folders and registry:
                  .\Extensions\Ruby Console+[ver
                  • .\Plugins_ae\Console
                  • .\WebDialog_AE_Console[/list⭕2x1uqeh5]]
                  After delete, it must work!
                  On other windows versions, the registry might be in similiar named locations.
                    Anton_S
                    Other than the registry the ruby console is outstanding! 😍
                    Highligh entities, beatiful script highlightings, fast processing, and much more. 👍
                    I only had to go to Plugins\ae_Console\jQuery\jquery-console-extensions.js and comment out all the DEBUG "puts" sections -- It disturbed me posting "resizing", and "finish resizing".
                    Now the wish! Is there a way to add a "clear history" button, so it clears all the console history input queue? To clear, i can go to registry and clear it out manually, although it would be nice to have a button.
                    • Chris FullmerC
                      I'm so glad you explained how to remove all the resizing puts statements. I just installed this and I was already ready to never use it again until that was fixed.
                      Otherwise pretty cool. Thanks!
                      • rami_lpmR
                        rami_lpm
                        Thanks Anton, this was bothering me too.
                          Aerilius
                          Sorry for that mistake, I fixed it!
                            Aerilius
                            Minor update (1.0.9):
                            • added icon
                              Aerilius
                              I added improvements for higher dpi settings.
                                Aerilius
                                A new version has been uploaded!
                                Ruby Console+ 2.0 is more robust, more powerful and more beautiful!
                                • renderizaR
                                  renderiza
                                  The perfect companion for testing code thanks!
                                  [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                                    Anton_S
                                    Wow!!! 😍
                                    Aerilius, you're so amazing!!!
                                    Variety of style templates, bigger input zone, that's just amazing
                                      Aerilius
                                      An update is ready!
                                      By replacing ace editor 1.1.0 by version 1.1.2, we now have auto-completion (ctrl+space) and code snippets support. I connected the autocompleter to Ruby so that it displays only completions (methods etc.) that are available in the current context.
                                      http://sketchucation.com/forums/download/file.php?id=115857
                                      Apart from that, modified scripts are now reloaded automatically.
                                        Anton_S
                                        Amazing update! 👍
                                        I can't wait to check it, since I'm not at my home computer now.
                                          matt.gordon320
                                          Hello!
                                          I'm getting this error. I'm using Fredo's Additional Plugin Folders script to control who in our firm has access to which plugins, just for reference. Any thoughts on what it might be?
                                            Aerilius
                                            That is a Javascript error caused by something in ace.js (you're not getting a popup error because I redirect such errors into the console). When I integrated ace into the webdialog there were a couple of incompatibilities with IE, that I tried to patch. It seems I didn't get that one. I'll try to work-around it. Thanks for reporting!
                                            • 2 / 4
