    [Plugin] Ruby Console+ (3.0.2) – updated 30.10.2017
    61 Posts 18 Posters 42.6k Views 17 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      Ruby console on steroids! Very nice.
      Cheers,
      Alex
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
        Aerilius
        New features added:
        inspector for SketchUp entities and many little improvements.
          Anton_S
          Thankyou, thnakyou, thankyou!!!
          I use it all the time 👍
          • Dan RathbunD Offline
            Dan Rathbun
            I have sizing issues on XP w/ IE8 installed. (SU v8.0M4)
            I'm not here much anymore.
              Aerilius
              That is not (only) a sizing issue, the JavaScript does not run. Maybe something in the WebDialog-Ruby communication goes wrong and does not call the %(#000000)[initialize()] function?
                Reind Brackman
                Just installed Ruby Console+ and my productivity doubled already.
                Also very good to avoid RSI, better known as 'lets load the damn script again command...'
                Thanks - great work.
                  cesaro36
                  Could anyone solve this issue?
                  Same Problem
                    Aerilius
                    What same problem? What browser? What version of the plugin?
                    Can you try the latest version?
                    • rami_lpmR Offline
                      rami_lpm
                      All I'm getting is this.
                      Win Vista Business 64
                      Java 7 update 7
                      IE 7 <--- is this a problem?
                        Aerilius
                        That might be the problem.
                        Requirements:
                        for now, it works only in the Windows version of SketchUp (IE8, IE9)
                        (Does Internet Explorer 7 run on Vista??)
                        • rami_lpmR Offline
                          rami_lpm
                          Was that 'requirements' line there all the time?
                          Yes, IE7 was installed with my spanish version.
                          I upgraded and it works fine.
                            Anton_S
                            I had the same problem as in the posts before. To resolve the problem you must delete the registry of original Ruby Console +: (Windows 7)
                            [list:2x1uqeh5][:2x1uqeh5]Go to start menu and search, and open regedit.exe.[/Ⓜ2x1uqeh5]
                            [:2x1uqeh5]Locate registry path: Computer\HKEY_CURRENT_USER\Software\Google\SketchUp[n][/Ⓜ2x1uqeh5]
                            [:2x1uqeh5]Delete the following folders and registry:
                            .\Extensions\Ruby Console+[ver
                            • .\Plugins_ae\Console
                            • .\WebDialog_AE_Console[/list⭕2x1uqeh5]]
                            After delete, it must work!
                            On other windows versions, the registry might be in similiar named locations.
                              Anton_S
                              Other than the registry the ruby console is outstanding! 😍
                              Highligh entities, beatiful script highlightings, fast processing, and much more. 👍
                              I only had to go to Plugins\ae_Console\jQuery\jquery-console-extensions.js and comment out all the DEBUG "puts" sections -- It disturbed me posting "resizing", and "finish resizing".
                              Now the wish! Is there a way to add a "clear history" button, so it clears all the console history input queue? To clear, i can go to registry and clear it out manually, although it would be nice to have a button.
                              • Chris FullmerC Offline
                                I'm so glad you explained how to remove all the resizing puts statements. I just installed this and I was already ready to never use it again until that was fixed.
                                Otherwise pretty cool. Thanks!
                                • rami_lpmR Offline
                                  rami_lpm
                                  Thanks Anton, this was bothering me too.
                                    Aerilius
                                    Sorry for that mistake, I fixed it!
                                      Aerilius
                                      Minor update (1.0.9):
                                      • added icon
                                        Aerilius
                                        I added improvements for higher dpi settings.
                                          Aerilius
                                          A new version has been uploaded!
                                          Ruby Console+ 2.0 is more robust, more powerful and more beautiful!
                                          • renderizaR Offline
                                            renderiza
                                            The perfect companion for testing code thanks!
                                            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                                            • 2 / 4
