    [Plugin] Ruby Console+ (3.0.2) – updated 30.10.2017
    61 Posts 18 Posters 41.2k Views 17 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      I have sizing issues on XP w/ IE8 installed. (SU v8.0M4)
      I'm not here much anymore.
        Aerilius
        That is not (only) a sizing issue, the JavaScript does not run. Maybe something in the WebDialog-Ruby communication goes wrong and does not call the %(#000000)[initialize()] function?
          Reind Brackman
          Just installed Ruby Console+ and my productivity doubled already.
          Also very good to avoid RSI, better known as 'lets load the damn script again command...'
          Thanks - great work.
            cesaro36
            Could anyone solve this issue?
            Same Problem
              Aerilius
              What same problem? What browser? What version of the plugin?
              Can you try the latest version?
              • rami_lpmR Offline
                rami_lpm
                All I'm getting is this.
                Win Vista Business 64
                Java 7 update 7
                IE 7 <--- is this a problem?
                  Aerilius
                  That might be the problem.
                  Requirements:
                  for now, it works only in the Windows version of SketchUp (IE8, IE9)
                  (Does Internet Explorer 7 run on Vista??)
                  • rami_lpmR Offline
                    rami_lpm
                    Was that 'requirements' line there all the time?
                    Yes, IE7 was installed with my spanish version.
                    I upgraded and it works fine.
                      Anton_S
                      I had the same problem as in the posts before. To resolve the problem you must delete the registry of original Ruby Console +: (Windows 7)
                      [list:2x1uqeh5][:2x1uqeh5]Go to start menu and search, and open regedit.exe.[/Ⓜ2x1uqeh5]
                      [:2x1uqeh5]Locate registry path: Computer\HKEY_CURRENT_USER\Software\Google\SketchUp[n][/Ⓜ2x1uqeh5]
                      [:2x1uqeh5]Delete the following folders and registry:
                      .\Extensions\Ruby Console+[ver
                      • .\Plugins_ae\Console
                      • .\WebDialog_AE_Console[/list⭕2x1uqeh5]]
                      After delete, it must work!
                      On other windows versions, the registry might be in similiar named locations.
                        Anton_S
                        Other than the registry the ruby console is outstanding! 😍
                        Highligh entities, beatiful script highlightings, fast processing, and much more. 👍
                        I only had to go to Plugins\ae_Console\jQuery\jquery-console-extensions.js and comment out all the DEBUG "puts" sections -- It disturbed me posting "resizing", and "finish resizing".
                        Now the wish! Is there a way to add a "clear history" button, so it clears all the console history input queue? To clear, i can go to registry and clear it out manually, although it would be nice to have a button.
                        • Chris FullmerC Offline
                          I'm so glad you explained how to remove all the resizing puts statements. I just installed this and I was already ready to never use it again until that was fixed.
                          Otherwise pretty cool. Thanks!
                          • rami_lpmR Offline
                            rami_lpm
                            Thanks Anton, this was bothering me too.
                              Aerilius
                              Sorry for that mistake, I fixed it!
                                Aerilius
                                Minor update (1.0.9):
                                • added icon
                                  Aerilius
                                  I added improvements for higher dpi settings.
                                    Aerilius
                                    A new version has been uploaded!
                                    Ruby Console+ 2.0 is more robust, more powerful and more beautiful!
                                    • renderizaR Offline
                                      renderiza
                                      The perfect companion for testing code thanks!
                                      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                                        Anton_S
                                        Wow!!! 😍
                                        Aerilius, you're so amazing!!!
                                        Variety of style templates, bigger input zone, that's just amazing
                                          Aerilius
                                          An update is ready!
                                          By replacing ace editor 1.1.0 by version 1.1.2, we now have auto-completion (ctrl+space) and code snippets support. I connected the autocompleter to Ruby so that it displays only completions (methods etc.) that are available in the current context.
                                          http://sketchucation.com/forums/download/file.php?id=115857
                                          Apart from that, modified scripts are now reloaded automatically.
                                            Anton_S
                                            Amazing update! 👍
                                            I can't wait to check it, since I'm not at my home computer now.
                                            • 2 / 4
