    Fill a space randomly
    10 Posts 5 Posters 1.1k Views 5 Watching
    • V Offline
      valerostudio
      Is there a script out there that will let you fill a defined space with a component(s) randomly? I have tried Component Sprayer but what I need is to fill a volume. Example. Fill a picture of water with ice cube components.
      • rodrigonotorR Offline
        rodrigonotor
        Hi Valero, maybe you can use the plugin Fur, insted grass, you can make it with your component.
        http://forums.sketchucation.com/viewtopic.php?t=28092#p243652
        One question, what use for your render, Artlantis?
        Regards
        β€’ Sketchando.net β€’ www.arqcad.net β€’
        • V Offline
          valerostudio
          Thanks guys.
          VRay all day
          • jeff hammondJ Offline
            jeff hammond
            you could try using sketchy physics for this.. (though you'll have to take the time to figure out how to use sketchy physics first πŸ˜‰ )
            put all the ice cubes above a container then drop them.. they'll bounce around etc and end up in random positions without overlapping each other..
            dotdotdot
              Fill a "big box" of a little components cubes
              Make an intersection = you have your volume completly filling
              Now use the Random selection by Tig for erase some cubes
              Another method If you want some different position of a same component in the space
              Use the tricky Sdmitch Pilou 24 Positions(this will the "Source")
              use it with some variation of orientation of the cube)
              In fact no need to use it in your special case! Just take 3 orientions of a cube and use the plug follow πŸ˜„
              And the Tricky Random replacement of a component! (the "Target" will be the "big box intersected above)
              Another method with Sketchyphysics
              Drop any objets (grouped) in your volume πŸ˜„
                jeff hammond
                [flash=853,480:o7yukqmr]http://www.youtube.com/v/pLK-eu2edcs?version=3&hl=en_US&rel=0[/flash:o7yukqmr]
                manhattan reflections
                dotdotdot
                • brookefoxB Offline
                  brookefox
                  I ain't complainin'.
                  You win.
                  ~ Brooke
                    jeff hammond
                    You win.
                    πŸ˜†
                    dotdotdot
                      Yes Sketchyphysics is the more funy for make that! πŸ‘
                      (as i said as third possibily in my previous post πŸ˜‰
                      Except if the hole of the volume is very tiny! πŸ’š
                      So you must cut it and recap at the end πŸ˜„
                      • V Offline
                        valerostudio
                        That is ..... AWESOME!!!!!!!!!!!!!!!!!
